[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta1-34-gb58339cce
Fri Nov 26 09:59:58 PST 2021
the project "PostGIS".
       via  b58339cce2df86cca7d6b5ad97e415836edc9caf (commit)
       via  e10058ad184131e4284d047a629b3c2fbff7fe55 (commit)
      from  aa7add4bad2bf439106025509c4260adad0acbd8 (commit)
revisions in full, below.
commit b58339cce2df86cca7d6b5ad97e415836edc9caf
Merge: aa7add4ba e10058ad1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Nov 26 09:59:53 2021 -0800
    Merge branch 'master-pcre-missing'
commit e10058ad184131e4284d047a629b3c2fbff7fe55
Date:   Thu Nov 25 15:58:07 2021 -0800
    add action in case of pkgconfig failure on pcre1
diff --git a/configure.ac b/configure.ac
index aa330ebf3..f41bbfb2a 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1222,18 +1222,18 @@ if test "x$with_address_standardizer" != "xno"; then
                         AC_MSG_RESULT([found pcre2.h])
-                		AC_CHECK_FILE("$PCREDIR/include/pcre.h",
-	                        PCRE_CPPFLAGS="-I$PCREDIR/include"
-	                        PCRE_LDFLAGS="-L$PCREDIR/lib -lpcre"
-	                        HAVE_PCRE1=yes
-	                        ADDRESS_STANDARDIZER="address_standardizer"
+                        AC_CHECK_FILE("$PCREDIR/include/pcre.h",
+	                          PCRE_CPPFLAGS="-I$PCREDIR/include"
+	                          PCRE_LDFLAGS="-L$PCREDIR/lib -lpcre"
+	                          HAVE_PCRE1=yes
+	                          ADDRESS_STANDARDIZER="address_standardizer"
                             AC_MSG_RESULT([found pcre.h])
                             AC_MSG_RESULT([no])
-                			AC_MSG_ERROR(["Could not find PCRE header in $PCREDIR/include"])
+                            AC_MSG_ERROR(["Could not find PCRE header in $PCREDIR/include"])
             else
                 AC_MSG_ERROR([the --with-pcredir directory "$PCREDIR" cannot be found])
@@ -1241,19 +1241,20 @@ if test "x$with_address_standardizer" != "xno"; then
         fi
     elif test ! -z "$PKG_CONFIG"; then
         PKG_CHECK_MODULES([PCRE2], [libpcre2-8], [
-                PCRE_CPPFLAGS="$PCRE2_CFLAGS"
-                PCRE_LDFLAGS="$PCRE2_LIBS"
+            PCRE_CPPFLAGS="$PCRE2_CFLAGS"
+            PCRE_LDFLAGS="$PCRE2_LIBS"
+            HAVE_PCRE2=yes
+            PKG_CHECK_MODULES([PCRE], [libpcre], [
+                PCRE_CPPFLAGS="$PCRE_CFLAGS"
+                PCRE_LDFLAGS="$PCRE_LIBS"
-                HAVE_PCRE2=yes
-                PKG_CHECK_MODULES([PCRE], [libpcre], [
-                    PCRE_CPPFLAGS="$PCRE_CFLAGS"
-                    PCRE_LDFLAGS="$PCRE_LIBS"
-                    HAVE_PCRE1=yes
+                HAVE_PCRE1=yes
+                ADDRESS_STANDARDIZER=""
     fi
     if test "x$HAVE_PCRE2" = "xyes"; then
Summary of changes:
 configure.ac | 43 ++++++++++++++++++++++---------------------
 1 file changed, 22 insertions(+), 21 deletions(-)
hooks/post-receive
