[postgis-tickets] [PostGIS] #4782: postgis_restore.pl does not handle recent pg_dump public schema change
PostGIS trac at osgeo.org
Thu Sep 2 04:54:52 PDT 2021
  Reporter:  mbanck   |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.4
 Component:  postgis  |    Version:  3.0.x
Resolution:  fixed    |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"6809237109671ebba3c249772fe884e67e4006f6/git" 6809237/git]:
 #!CommitTicketReference repository="git"
 revision="6809237109671ebba3c249772fe884e67e4006f6"
 Set postgis installation schema by default to the schema found in dump
 Closes #4782
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4782#comment:8>
