[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-497-g9903f54
Thu Sep 2 14:05:22 PDT 2021
the project "PostGIS".
       via  9903f546f0087c9bd135d483b8ad74a8e987c5b6 (commit)
       via  0c09010bd18ff28851554639270162ec3ad2c508 (commit)
       via  8a075c133407ddc5ec35231e4bc7a0e2c0d7df57 (commit)
       via  14afc48bfab0f64320d87ecf8f4445224b19eab8 (commit)
      from  b4387f1810a25185e0b250e794a4ab40ba78f7bc (commit)
revisions in full, below.
commit 9903f546f0087c9bd135d483b8ad74a8e987c5b6
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Sep 2 23:59:15 2021 +0300
    NEWS for non-simplifying ST_AsMVTGeom.
diff --git a/NEWS b/NEWS
index be39bd8..7c5d0fa 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,9 @@ PostGIS 3.2.0
   - #4824, Removed `--without-wagyu` build option. Using Wagyu is now mandatory to build with MVT support.
   - #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
   - #4981, ST_StartPoint support any geometry. No longer returns null for non-linestrings.
+  - #4149, ST_AsMVTGeom now preserves more of original geometry's details at scale close to target extent.
+           If you need previous simplifying behaviour, you can ST_Simplify the geometry in advance.
+           (Darafei Praliaskouski)
  * Enhancements *
   - #2592, Do not allow CreateTopology to define topologies with SRID < 0
commit 0c09010bd18ff28851554639270162ec3ad2c508
Merge: b4387f1 8a075c1
Date:   Thu Sep 2 23:46:59 2021 +0300
    Zero tolerance simplification in MVT export.
    Closes #4149
    Closes https://github.com/postgis/postgis/pull/463
commit 8a075c133407ddc5ec35231e4bc7a0e2c0d7df57
Merge: 18ce69f 14afc48
Date:   Thu Sep 2 22:26:20 2021 +0300
    Merge 14afc48bfab0f64320d87ecf8f4445224b19eab8 into 18ce69feba33b13d9fc6122dd594669d9b1bb977
diff --cc regress/core/mvt_expected
index b53be37,da0a9ac..9b6e5c1
--- a/regress/core/mvt_expected
+++ b/regress/core/mvt_expected
@@@ -45,11 -45,11 +45,11 @@@ PG38
  PG39|t
  PG40 - ON |LINESTRING(0 10,0 0)
  PG40 - OFF|LINESTRING(0 10,0 0)
- PG41 - ON |LINESTRING(0 10,0 4,0 2,0 0,1 0)
- PG41 - OFF|LINESTRING(0 10,0 4,0 2,0 0,1 0)
+ PG41 - ON |LINESTRING(0 10,0 0,1 0)
+ PG41 - OFF|LINESTRING(0 10,0 0,1 0)
  PG42 - ON |LINESTRING(0 10,0 0,1 0)
  PG42 - OFF|LINESTRING(0 10,0 0,1 0)
 -PG43 - ON |MULTIPOLYGON(((5 5,0 0,10 0,5 5)),((5 5,10 10,0 10,5 5)))
 +PG43 - ON |MULTIPOLYGON(((0 10,10 10,5 5,0 10)),((0 0,5 5,10 0,0 0)))
  PG43 - OFF|MULTIPOLYGON(((5 5,-1 -1,11 -1,5 5)),((5 5,11 11,-1 11,5 5)))
  PG44|
  PG45|
commit 14afc48bfab0f64320d87ecf8f4445224b19eab8
Date:   Sun Aug 18 16:14:20 2019 +0300
diff --git a/postgis/mvt.c b/postgis/mvt.c
index e1fc085..8733823 100644
--- a/postgis/mvt.c
+++ b/postgis/mvt.c
@@ -1180,7 +1180,7 @@ LWGEOM *mvt_geom(LWGEOM *lwgeom, const GBOX *gbox, uint32_t extent, uint32_t buf
 	gridspec grid = {0, 0, 0, 0, 1, 1, 0, 0};
 	double width = gbox->xmax - gbox->xmin;
 	double height = gbox->ymax - gbox->ymin;
-	double resx, resy, res, fx, fy;
+	double fx, fy;
 	const uint8_t basic_type = lwgeom_get_basic_type(lwgeom);
 	int preserve_collapsed = LW_FALSE;
 	POSTGIS_DEBUG(2, "mvt_geom called");
@@ -1192,16 +1192,9 @@ LWGEOM *mvt_geom(LWGEOM *lwgeom, const GBOX *gbox, uint32_t extent, uint32_t buf
 	if (lwgeom_is_empty(lwgeom))
 		return NULL;
-	resx = width / extent;
-	resy = height / extent;
-	res = (resx < resy ? resx : resy)/2;
 	fx = extent / width;
 	fy = -(extent / height);
-	/* Remove all non-essential points (under the output resolution) */
-	lwgeom_remove_repeated_points_in_place(lwgeom, res);
-	lwgeom_simplify_in_place(lwgeom, res, preserve_collapsed);
 	/* If geometry has disappeared, you're done */
 		return NULL;
@@ -1217,6 +1210,13 @@ LWGEOM *mvt_geom(LWGEOM *lwgeom, const GBOX *gbox, uint32_t extent, uint32_t buf
 	/* Snap to integer precision, removing duplicate points */
 	lwgeom_grid_in_place(lwgeom, &grid);
+	/* Remove points on straight lines */
+	lwgeom_simplify_in_place(lwgeom, 0, preserve_collapsed);
+	/* Remove duplicates in multipoints */
+	if (lwgeom->type == MULTIPOINTTYPE)
+		lwgeom_remove_repeated_points_in_place(lwgeom, 0);
 	if (!lwgeom || lwgeom_is_empty(lwgeom))
 		return NULL;
diff --git a/regress/core/mvt_expected b/regress/core/mvt_expected
index e88d4b0..da0a9ac 100644
@@ -45,8 +45,8 @@ PG38|
 PG39|t
-PG41 - ON |LINESTRING(0 10,0 4,0 2,0 0,1 0)
-PG41 - OFF|LINESTRING(0 10,0 4,0 2,0 0,1 0)
+PG41 - ON |LINESTRING(0 10,0 0,1 0)
+PG41 - OFF|LINESTRING(0 10,0 0,1 0)
Summary of changes:
 NEWS                      |  3 +++
 postgis/mvt.c             | 16 ++++++++--------
 regress/core/mvt_expected |  4 ++--
 3 files changed, 13 insertions(+), 10 deletions(-)
hooks/post-receive
