[postgis-tickets] [PostGIS] #4988: SFCGAL doesn't specify unknown type
PostGIS trac at osgeo.org
Sat Sep 4 23:13:08 PDT 2021
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  assigned
  Priority:  low     |  Milestone:  PostGIS 3.1.5
 Component:  sfcgal  |    Version:  master
Resolution:          |   Keywords:
Description changed by robe:
Old description:
> Minor issue but:
> ST_3DDifference returns:
> ERROR:  LWGEOM2SFCGAL: Unknown geometry type !
> With curved surfaces - a query such as:
> SELECT ST_3DDifference('POLYHEDRALSURFACE Z (((-72.2 41.755 0,-72.2
> 41.755 1,-72.2 42.755 1,-72.2 42.755 0,-72.2 41.755 0)),((-72.2 41.755
> 0,-72.2 42.755 0,-71.2 42.755 0,-71.2 41.755 0,-72.2 41.755 0)),((-72.2
> 41.755 0,-71.2 41.755 0,-71.2 41.755 1,-72.2 41.755 1,-72.2 41.755
> 0)),((-71.2 42.755 0,-71.2 42.755 1,-71.2 41.755 1,-71.2 41.755 0,-71.2
> 42.755 0)),((-72.2 42.755 0,-72.2 42.755 1,-71.2 42.755 1,-71.2 42.755
> 0,-72.2 42.755 0)),((-72.2 41.755 1,-71.2 41.755 1,-71.2 42.755 1,-72.2
> 42.755 1,-72.2 41.755 1)))'::geometry,'
> MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(-71.0821 42.3036,-71.4821
> 42.3036,-71.7821 42.7036,-71.0821 42.7036,-71.0821 42.3036),(-71.1821
> 42.4036,-71.3821 42.6036,-71.3821 42.4036,-71.1821
> 42.4036)))'::geometry);
New description:
 Minor issue but:
 SELECT ST_3DDifference('POLYHEDRALSURFACE Z (((-72.2 41.755 0,-72.2 41.755
 1,-72.2 42.755 1,-72.2 42.755 0,-72.2 41.755 0)),((-72.2 41.755 0,-72.2
 42.755 0,-71.2 42.755 0,-71.2 41.755 0,-72.2 41.755 0)),((-72.2 41.755
 0,-71.2 41.755 0,-71.2 41.755 1,-72.2 41.755 1,-72.2 41.755 0)),((-71.2
 42.755 0,-71.2 42.755 1,-71.2 41.755 1,-71.2 41.755 0,-71.2 42.755
 0)),((-72.2 42.755 0,-72.2 42.755 1,-71.2 42.755 1,-71.2 42.755 0,-72.2
 42.755 0)),((-72.2 41.755 1,-71.2 41.755 1,-71.2 42.755 1,-72.2 42.755
 42.4036,-71.3821 42.6036,-71.3821 42.4036,-71.1821 42.4036)))'::geometry);
 Same issue with ST_3DUnion
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4988#comment:1>
