[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-506-ga16cf9a
    git at osgeo.org
    git at osgeo.org
    Fri Sep 10 09:40:30 PDT 2021
the project "PostGIS".
       via  a16cf9a97fc63a3b96cddb6e4895a074feba5664 (commit)
      from  d77e8b01b6d485d8e2564c96b438ec31790a3f02 (commit)
revisions in full, below.
commit a16cf9a97fc63a3b96cddb6e4895a074feba5664
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Sep 10 12:39:46 2021 -0400
    Remove ci/reallie and regress/real
    All performance tests are now in
    https://git.osgeo.org/gitea/postgis/postgis-performance
diff --git a/ci/reallie/pg_init_start.sh b/ci/reallie/pg_init_start.sh
deleted file mode 100644
index 34088b2..0000000
--- a/ci/reallie/pg_init_start.sh
+++ /dev/null
@@ -1,37 +0,0 @@
-# Reallie is a 64-bit Debian 11, residing in same host as debbie
-# She will be used for testing real data tests (those in real folder)
-# This is script to launch custom compiled PostgreSQL
-# export label=reallie #this is passed in via Jenkins
-export WORKSPACE=/home/jenkins/workspace
-export OS_BUILD=64
-export PG_VER=14
-export PGPATH=${WORKSPACE}/pg/label/${label}/rel/pg${PG_VER}w${OS_BUILD}
-export PATH=${PATH}:${PGPATH}/bin:${PGPATH}/lib
-export PGPORT=55432
-export PGDATA=$PGPATH/data_${PGPORT}
-export PGLOG="$PGDATA/pgsql.log"
-# What to use to start up the postmaster
-DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -o '-F' -l logfile start"
-# What to use to shut down the postmaster
-PGCTL="$PGPATH/bin/pg_ctl"
-# remove cluster if exists
-if [ -d $PGDATA ] ; then
-    if [ -d $PGDATA/postmaster.pid ] ; then
-    	$PGCTL stop -D $PGDATA -s -m fast
-    fi;
-    rm -rf $PGDATA
-fi;
-#initialize cluster
-$PGPATH/bin/initdb
-echo -n "Starting PostgreSQL: "
-$DAEMON &
-#sleep a bit because sometimes postgres takes a bit to start up
-sleep 20
-echo "ok"
-exit 0
diff --git a/ci/reallie/postgis_regress.sh b/ci/reallie/postgis_regress.sh
index 7907d75..0000000
--- a/ci/reallie/postgis_regress.sh
+++ /dev/null
@@ -1,36 +0,0 @@
-#!/bin/bash
-## BRANCH is passed in via jenkins which is set via gitea web hook
-#export BRANCH=618a67b1d6fc223dd5a4c0b02c824939f21dbd65
-## label is set by jenkins
-#export label=${label}
-## TODO: Determine what will trigger reallie to move
-export DOWNLOAD_DATADIR=${WORKSPACE}/download_data
-cd ${WORKSPACE}/PostGIS_Worker_Run/label/${label}/$BRANCH
-export OS_BUILD=64
-export PG_VER=14
-export PATH=${PGPATH}/bin:${PGPATH}/lib:${PATH}
-export PGHOST=localhost
-sh autogen.sh
-./configure --with-pgconfig=${PGPATH}/bin/pg_config
-#make clean
-make
-export err_status=0
-make install
-cd regress/real
-make check
-err_status=$?
-if [ -d $PGDATA/postmaster.pid ] ; then
-fi
-exit $err_status
diff --git a/regress/real/Makefile.in b/regress/real/Makefile.in
index 16f032c..0000000
--- a/regress/real/Makefile.in
+++ /dev/null
@@ -1,44 +0,0 @@
-DATABASE=postgis_reg
-PERL=@PERL@
-# MingW hack: rather than use PGSQL_BINDIR directly, we change to the directory and
-# then use "pwd" to return the path. This ensures that the returned path is in MSYS
-# format, otherwise colons in drive letters will break PATH.
-PGSQL_BINDIR=$(shell cd "@PGSQL_BINDIR@" && pwd)
-ifndef DOWNLOAD_DATADIR
-	DOWNLOAD_DATADIR=$(srcdir)/download_data
-endif
-# Put path from pg_config into front of search path
-PATH := $(PGSQL_BINDIR):$(PATH)
-export PATH
-all:
-	@echo "Use 'make check' to run all tests"
-download_data:
-	sh download_data.sh
-%.sql: %.sql.in
-	$(PERL) -lpe "s'@DOWNLOAD_DATADIR@'$(DOWNLOAD_DATADIR)'g" $< > $@
-clean:
-	rm -f load_data.sql
-distclean: clean
-	rm -rf $(DOWNLOAD_DATADIR)
-check-regress-deps: download_data load_data.sql
-check-regress: check-regress-deps
-topsrcdir = $(realpath ../../)
-srcdir = $(realpath .)
-include tests.mk
-include ../runtest.mk
-check: check-regress
diff --git a/regress/real/README b/regress/real/README
index bd7d96a..0000000
--- a/regress/real/README
+++ /dev/null
@@ -1,76 +0,0 @@
-The real folder is the home for tests involving real world data.
-To run these tests:
-cd regress/real
-make check
-It includes a download_data.sh script that downloads data from http://postgis.net/extra/test-data
-Data in http://postgis.net/extra/test-data is currently sourced from Census Tiger and OSM data sources and is packaged
-in a format suitable for load by psql.
-If you want to control where the data is downloaded to, set env variable
-export DOWNLOAD_DATADIR=/path/to_download_data
-If path is not set, a download_data folder will created in this folder and removed with make distclean
-The data sources available there are as follows:
-tiger_national.sql.bz2 - this requires the postgis_tiger_geocoder extension to be loaded before hand as it inherits from the tables packaged with that. The data is from https://www2.census.gov/geo/tiger/TIGER2020/ (zcta5, state, county)
-tiger_dc.sql.bz2 - this requires the postgis_tiger_geocoder extension.  Data sourced from https://www2.census.gov/geo/tiger/TIGER2020/*/tl_2020_11*_*.zip files
-tiger_ma.sql.bz2 - this requires the postgis_tiger_geocoder extension.  Data sourced from https://www2.census.gov/geo/tiger/TIGER2020/*/tl_2020_25*_*.zip files
-osm_belarus.sql.bz2 - this is sourced from https://download.geofabrik.de/europe/belarus-latest.osm.pbf dated 2021-06-28T20:21:42Z
-osm_china.sql.bz2 - this is sourced from https://download.geofabrik.de/asia/china-140101-free.shp.zip dated 2018-05-03 16:26
-Requirements for run_test.pl
-run_test.pl requires the following Perl modules to be installed
- Text::Diff;
- File::Which;
- File::Basename;
- File::Temp 'tempdir';
- File::Copy;
- File::Path 'make_path';
- File::Path 'remove_tree';
- Cwd 'abs_path';
- Getopt::Long;
-Most distributions of Perl will have everything except Text::Diff and File::Which.
-To install them from the command-line, as root run
- cpan Text::Diff
- cpan File::Which
-How to add a regression test
-1. Add any needed data sources to download_data.sh (later we might break this up)
-2. Add a psql load line to load_data.sql script and edit tests.mk and add the script RUNTESTFLAGS_INTERNAL
-3. Write a <testname>.sql file with data and sql queries for testing
-4. Write a <testname>_expected or <testname>_expected.in file with
-   expected results per query
-   The expected results provided in the <testname>_expected file must be
-   formatted using the following psql options:
-      -a -- unaligned columns
-      -f | -- use | (pipe) as the field separator between columns
-      -t -- output rows only, ie. no table header
-   cat file.sql | psql -F\| -t -A > file_expected
-3. Edit tests.mk adding <testname> to the TESTS variable.
-   Any _expected.in files need to be added to the PREPROC variable.
-Optional:
-   If your test has unusual setup or teardown requirements, you may create
-   any of the following optional files (they will run in this order):
-        <testname>-pre.sh
-        <testname>-pre.sql   (run via psql)
-                 (The test itself is run here.)
-        <testname>-post.sql  (run via psql)
-        <testname>-post.sh
diff --git a/regress/real/download_data.sh b/regress/real/download_data.sh
index 5274873..0000000
--- a/regress/real/download_data.sh
+++ /dev/null
@@ -1,20 +0,0 @@
-#!/bin/sh
-export TESTSITE="http://postgis.net/extra/test-data"
-if [ -z "$DOWNLOAD_DATADIR" ]; then
-	DOWNLOAD_DATADIR=$(dirname "$0")/download_data
-fi
-mkdir -p $DOWNLOAD_DATADIR
-cd $DOWNLOAD_DATADIR
-echo $DOWNLOAD_DATADIR
-wget -nc ${TESTSITE}/tiger_national.sql.bz2 -O tiger_national.sql.bz2
-wget -nc ${TESTSITE}/tiger_dc.sql.bz2 -O tiger_dc.sql.bz2
-wget -nc ${TESTSITE}/osm_china.sql.bz2 -O osm_china.sql.bz2
-wget -nc ${TESTSITE}/osm_belarus.sql.bz2 -O osm_belarus.sql.bz2
-bzip2 -dk tiger_national.sql.bz2
-bzip2 -dk tiger_dc.sql.bz2
-bzip2 -dk osm_china.sql.bz2
-bzip2 -dk osm_belarus.sql.bz2
-echo "Done downloading data"
diff --git a/regress/real/drop_data.sql b/regress/real/drop_data.sql
index 23953ec..0000000
--- a/regress/real/drop_data.sql
+++ /dev/null
@@ -1,4 +0,0 @@
-DROP SCHEMA osm_china CASCADE;
-DROP SCHEMA tiger_data CASCADE;
-DROP SCHEMA osm_belarus CASCADE;
-CREATE SCHEMA tiger_data;
diff --git a/regress/real/index_tiger_data.sql b/regress/real/index_tiger_data.sql
index 9211182..0000000
--- a/regress/real/index_tiger_data.sql
+++ /dev/null
@@ -1,2 +0,0 @@
-set search_path=public,postgis,tiger,contrib,topology;
-SELECT tiger.install_missing_indexes();
diff --git a/regress/real/index_tiger_data_expected b/regress/real/index_tiger_data_expected
index 718f4d2..0000000
--- a/regress/real/index_tiger_data_expected
+++ /dev/null
@@ -1 +0,0 @@
-t
diff --git a/regress/real/load_data.sql.in b/regress/real/load_data.sql.in
index 019bede..0000000
--- a/regress/real/load_data.sql.in
+++ /dev/null
@@ -1,5 +0,0 @@
-ALTER TABLE tiger.zcta5 DROP CONSTRAINT IF EXISTS enforce_geotype_the_geom;
-\i @DOWNLOAD_DATADIR@/tiger_national.sql
-\i @DOWNLOAD_DATADIR@/tiger_dc.sql
-\i @DOWNLOAD_DATADIR@/osm_china.sql
-\i @DOWNLOAD_DATADIR@/osm_belarus.sql
diff --git a/regress/real/tests.mk b/regress/real/tests.mk
index 7f82b1d..0000000
--- a/regress/real/tests.mk
+++ /dev/null
@@ -1,20 +0,0 @@
-# * PostGIS - Spatial Types for PostgreSQL
-# * http://postgis.net
-# * Copyright (C) 2021 Regina Obe <lr at pcorp.us>
-# * This is free software; you can redistribute and/or modify it under
-# * the terms of the GNU General Public Licence. See the COPYING file.
-override RUNTESTFLAGS := $(RUNTESTFLAGS) --tiger --extension
-RUNTESTFLAGS_INTERNAL += \
-  --after-create-script $(topsrcdir)/regress/real/load_data.sql \
-	--before-uninstall-script $(topsrcdir)/regress/real/drop_data.sql
-TESTS += \
-	$(topsrcdir)/regress/real/index_tiger_data
Summary of changes:
 ci/reallie/pg_init_start.sh            | 37 -----------------
 ci/reallie/postgis_regress.sh          | 36 ----------------
 regress/real/Makefile.in               | 44 --------------------
 regress/real/README                    | 76 ----------------------------------
 regress/real/download_data.sh          | 20 ---------
 regress/real/drop_data.sql             |  4 --
 regress/real/index_tiger_data.sql      |  2 -
 regress/real/index_tiger_data_expected |  1 -
 regress/real/load_data.sql.in          |  5 ---
 regress/real/tests.mk                  | 20 ---------
 10 files changed, 245 deletions(-)
 delete mode 100644 ci/reallie/pg_init_start.sh
 delete mode 100644 ci/reallie/postgis_regress.sh
 delete mode 100644 regress/real/Makefile.in
 delete mode 100644 regress/real/README
 delete mode 100644 regress/real/download_data.sh
 delete mode 100644 regress/real/drop_data.sql
 delete mode 100644 regress/real/index_tiger_data.sql
 delete mode 100644 regress/real/index_tiger_data_expected
 delete mode 100644 regress/real/load_data.sql.in
 delete mode 100644 regress/real/tests.mk
hooks/post-receive
