[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-509-gd69349c
Fri Sep 10 11:23:00 PDT 2021
the project "PostGIS".
       via  d69349c8fa56d99abf105868b9139ba7eb4fe118 (commit)
      from  f6cbffe2367c641fab33d30bd3a68e49f70926e4 (commit)
revisions in full, below.
commit d69349c8fa56d99abf105868b9139ba7eb4fe118
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Sep 10 14:21:19 2021 -0400
    Get rid of regress/real in configure
    Fix proj website URL and change from proj4 to proj
    Add missing upgrade targets
    Start prepping news for release
diff --git a/NEWS b/NEWS
index b5676d3..16b4b87 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,87 @@
+PostGIS 3.2.0alpha1
+2021/09/xx
+This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9, Proj 6.1+, and PostgreSQL 14+
+ * Breaking changes *
+  - #4824, Removed `--without-wagyu` build option. Using Wagyu is now mandatory to build with MVT support.
+  - #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
+  - #4981, ST_StartPoint support any geometry. No longer returns null for non-linestrings.
+  - #4149, ST_AsMVTGeom now preserves more of original geometry's details at scale close to target extent.
+           If you need previous simplifying behaviour, you can ST_Simplify the geometry in advance.
+           (Darafei Praliaskouski)
+ * Enhancements *
+  - #2592, Do not allow CreateTopology to define topologies with SRID < 0
+           (Sandro Santilli)
+  - #3232, Prevent moving an isolated node to different face
+           (Sandro Santilli)
+  - Consider collection TopoGeometries while editing topology primitives.
+           (Sandro Santilli)
+  - #3248, Prevent removing isolated edges if used in a TopoGeometry
+           (Sandro Santilli)
+  - #3231, Prevent removing isolated nodes if used in a TopoGeometry
+           (Sandro Santilli)
+  - #3239, Prevent headling topology edges if the connecting node is
+           used in the definition of a TopoGeometry (Sandro Santilli)
+  - #4950, Speed up checking containing_face for nodes in ValidateTopology
+           (Sandro Santilli)
+  - #4945, Multi-shell face check in ValidateTopology (Sandro Santilli)
+  - #4944, Side-location conflict check in ValidateTopology (Sandro Santilli)
+  - #3042, ValidateTopology check for edge linking (Sandro Santilli)
+  - #3276, ValidateTopology check for face's mbr (Sandro Santilli)
+  - #4936, Bounding box limited ValidateTopology (Sandro Santilli)
+  - #4933, Speed up topology building in presence of big faces (Sandro Santilli)
+  - #3233, ValidateTopology check for node's containing_face (Sandro Santilli)
+  - #4830, ValidateTopology check for edges side face containment
+           (Sandro Santilli)
+  - #4827, Allow NaN coordinates in WKT input (Paul Ramsey)
+  - ST_Value() accepts resample parameter to add bilinear option (Paul Ramsey)
+  - #3778, #4401, ST_Boundary now works for TIN and does not linearize curves (Aliaksandr Kalenik)
+  - #4881, #4884, Store sign of edge_id for lineal TopoGeometry in relation table
+           to retain direction (Sandro Santilli)
+  - #4628, Add an option to disable ANALYZE when loading shapefiles (Stefan Corneliu Petrea)
+  - #4924, Faster ST_RemoveRepeatedPoints on large multipoints, O(NlogN) instead of O(N^2)
+           (Aliaksandr Kalenik, Darafei Praliaskouski)
+  - #4925, fix ST_DumpPoints to not overlook points (Aliaksandr Kalenik)
+  - ST_SRID(topogeometry) override, to speedup lookups (Sandro Santilli)
+  - #2175, Avoid creating additional nodes when adding same closed
+           line to topology (Sandro Santilli)
+  - #4974, Upgrade path for address_standardizer_data_us
+           (Jan Katins of Aiven, Regina Obe)
+  - #4975, PostGIS upgrade change to not use temp tables (Jan Katins of Aiven)
+  - #4981, ST_StartPoint support any geometry (Aliaksandr Kalenik)
+  - #4799, Include srs in GeoJSON where it exists in spatial_ref_sys.
+  - #4986, GIST indexes on Postgres 14 are now created faster using Hilbert-sorting method.
+           (Han Wang, Aliaksandr Kalenik, Darafei Praliaskouski, Giuseppe Broccolo)
+ * New features*
+  - #4923, topology.ValidateTopologyRelation (Sandro Santilli)
+  - #4933, topology.GetFaceContainingPoint (Sandro Santilli)
+  - #2175, ST_Scroll (Sandro Santilli)
+  - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
+  - #4869, FindLayer to quickly get a layer record (Sandro Santilli)
+  - #4851, TopoGeom_addTopoGeom function (Sandro Santilli)
+  - ST_MakeValid(geometry, options) allows alternative validity building
+    algorithms with GEOS 3.10 (Paul Ramsey)
+  - ST_InterpolateRaster() fills in raster cells between sample points
+    using one of a number of algorithms (inverse weighted distance, average, etc)
+    using algorithms from GDAL
+    (Paul Ramsey)
+  - ST_Contour() generates contour lines from raster values
+    using algorithms from GDAL (Paul Ramsey)
+  - ST_SetZ()/ST_SetM() fills in z/m coordinates of a geometry using data read
+    from a raster (Paul Ramsey)
+  - New postgis.gdal_vsi_options GUC allows out-db rasters on VSI network
+    services to be accessed with authentication keys, etc. (Paul Ramsey)
+  - ST_DumpSegments returns a set of segments of input geometry (Aliaksandr Kalenik)
+  - #4859, ST_Point, ST_PointZ, ST_PointM, ST_PointZM, constructors
+    with SRID parameter (Paul Ramsey)
+  - #4808, ST_ClusterKMeans now supports max_radius argument. Use it when you're not sure what is
+    the number of clusters but you know what the size of clusters should be. (Darafei Praliaskouski)
 PostGIS 3.2.0
 2021/xx/xx
diff --git a/README.postgis b/README.postgis
index a1ea9e0..e58f682 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.2.0dev
-:Date: 2021-xx-xx
+:Version: 3.2.0alpha1
+:Date: 2021-09-10
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
@@ -43,7 +43,7 @@ this to work.
   The PROJ4 catographic projection library is required if you want to use the
   ST_Transform() function to reproject features within the database.
-    http://trac.osgeo.org/proj/
+    https://proj.org
 * GEOS (Required, Version 3.6 or higher)
   - 3.9+ is needed to take advantage of
diff --git a/configure.ac b/configure.ac
index 422fd87..e633a9f 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1595,7 +1595,6 @@ AC_OUTPUT([GNUmakefile
    regress/core/tests.mk
    regress/dumper/Makefile
    regress/loader/Makefile
-	 regress/real/Makefile
    doc/Makefile
    doc/Makefile.comments
    doc/html/image_src/Makefile
diff --git a/doc/installation.xml b/doc/installation.xml
index 7a469ae..3964213 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -166,11 +166,11 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
 	  <listitem>
 		<para>
-		  Proj4 reprojection library. Proj4 4.9 or above is required.
-			The Proj4 library is used to provide coordinate reprojection support within
-		  PostGIS. Proj4 is available for download from
-		  <ulink url="http://trac.osgeo.org/proj/">
+		  Proj reprojection library. Proj 4.9 or above is required.
+			The Proj library is used to provide coordinate reprojection support within
+		  PostGIS. Proj is available for download from
+		  <ulink url="https://proj.org/">
+			https://proj.org/
 		  </ulink>
 		</para>
@@ -434,9 +434,9 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
 		  <term><command>--with-projdir=DIR</command></term>
 		  <listitem>
 			<para>
-			  Proj4 is a reprojection library required by PostGIS. Use this
+			  Proj is a reprojection library required by PostGIS. Use this
 			  parameter (<command>--with-projdir=/path/to/projdir</command>) to
-			  manually specify a particular Proj4 installation directory that
+			  manually specify a particular Proj installation directory that
 			  PostGIS will build against.
 			</para>
 		  </listitem>
@@ -740,7 +740,7 @@ CREATE EXTENSION postgis_tiger_geocoder FROM unpackaged;
 	  <note>
 		<para>
 		  If you configured PostGIS using non-standard PostgreSQL, GEOS, or
-		  Proj4 locations, you may need to add their library locations to the
+		  Proj locations, you may need to add their library locations to the
 		  <varname>LD_LIBRARY_PATH</varname> environment variable.
 		</para>
 	  </note>
@@ -1265,7 +1265,7 @@ pretty_address
 	<para>
 	  Also check that configure has correctly detected the location and version
-	  of PostgreSQL, the Proj4 library and the GEOS library.
+	  of PostgreSQL, the Proj library and the GEOS library.
 	</para>
 	<orderedlist>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 49bef65..4674adb 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -59,9 +59,11 @@ UPGRADEABLE_VERSIONS = \
 	3.0.1 \
 	3.0.2 \
 	3.0.3 \
-	3.0.4dev \
+	3.0.4 \
+	3.0.5dev \
 	3.1.0 \
 	3.1.1 \
 	3.1.2	\
 	3.1.3 \
-	3.1.4dev
+	3.1.4 \
+	3.1.5dev
Summary of changes:
 NEWS                               | 84 ++++++++++++++++++++++++++++++++++++++
 README.postgis                     |  6 +--
 configure.ac                       |  1 -
 doc/installation.xml               | 18 ++++----
 extensions/upgradeable_versions.mk |  6 ++-
 5 files changed, 100 insertions(+), 15 deletions(-)
hooks/post-receive
