[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-512-gc5ca9c1
Fri Sep 10 18:42:10 PDT 2021
the project "PostGIS".
       via  c5ca9c1d3ad058c26263c3f913ccfed8e9473660 (commit)
      from  fefbc85e9edc7482c9989bbc887903f43ec6ce88 (commit)
revisions in full, below.
commit c5ca9c1d3ad058c26263c3f913ccfed8e9473660
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Sep 10 21:36:09 2021 -0400
    Prepping for 3.2.0alpha1 release
diff --git a/NEWS b/NEWS
index 50f2ac3..2db6651 100644
--- a/NEWS
+++ b/NEWS
@@ -1,8 +1,8 @@
 PostGIS 3.2.0alpha1
-2021/09/xx
+2021/09/10
 This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
-Additional features are enabled if you are running GEOS 3.9, Proj 6.1+, and PostgreSQL 14+
+Additional features are enabled if you are running GEOS 3.9+, Proj 6.1+, and PostgreSQL 14+.
  * Breaking changes *
   - #4824, Removed `--without-wagyu` build option. Using Wagyu is now mandatory to build with MVT support.
@@ -11,6 +11,7 @@ Additional features are enabled if you are running GEOS 3.9, Proj 6.1+, and Post
   - #4149, ST_AsMVTGeom now preserves more of original geometry's details at scale close to target extent.
            If you need previous simplifying behaviour, you can ST_Simplify the geometry in advance.
            (Darafei Praliaskouski)
+  - Proj 4.9 or higher is required
  * Enhancements *
   - #2592, Do not allow CreateTopology to define topologies with SRID < 0
@@ -93,6 +94,7 @@ PostGIS 3.2.0
  * Enhancements *
@@ -137,6 +139,7 @@ PostGIS 3.2.0
   - #4799, Include srs in GeoJSON where it exists in spatial_ref_sys.
   - #4986, GIST indexes on Postgres 14 are now created faster using Hilbert-sorting method.
            (Han Wang, Aliaksandr Kalenik, Darafei Praliaskouski, Giuseppe Broccolo)
+  - #4949, Use proj_normalize_for_visualization to hand "axis swap" decisions (Paul Ramsey)
  * New features*
   - #4923, topology.ValidateTopologyRelation (Sandro Santilli)
diff --git a/Version.config b/Version.config
index 843963a..a29d574 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0alpha1
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 5119737..9af06cb 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -3,6 +3,95 @@
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
     <sect1>
+        <title>Release 3.2.0alpha1</title>
+        <para>Release date: 2021/09/10</para>
+        <para>This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9 or higher
+            Additional features are enabled if you are running GEOS 3.9+ (more with GEOS 3.10+), Proj 6.1+, or PostgreSQL 14+.</para>
+        <simplesect>
+            <title>Breaking changes</title>
+            <para>#4824, Removed `--without-wagyu` build option. Using Wagyu is now mandatory to build with MVT support.</para>
+            <para>#4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.</para>
+            <para>#4981, ST_StartPoint support any geometry. No longer returns null for non-linestrings.</para>
+            <para>#4149, ST_AsMVTGeom now preserves more of original geometry's details at scale close to target extent.
+                If you need previous simplifying behaviour, you can ST_Simplify the geometry in advance.
+                (Darafei Praliaskouski)</para>
+            <para>Proj 4.9 or higher is required.</para>
+        </simplesect>
+        <simplesect>
+            <title>Enhancements</title>
+             <para>#2592, Do not allow CreateTopology to define topologies with SRID > 0
+                        (Sandro Santilli)</para>
+             <para>#3232, Prevent moving an isolated node to different face
+             <para>Consider collection TopoGeometries while editing topology primitives.
+             <para>#3248, Prevent removing isolated edges if used in a TopoGeometry
+             <para>#3231, Prevent removing isolated nodes if used in a TopoGeometry
+             <para>#3239, Prevent headling topology edges if the connecting node is
+                        used in the definition of a TopoGeometry (Sandro Santilli)</para>
+             <para>#4950, Speed up checking containing_face for nodes in ValidateTopology
+             <para>#4945, Multi-shell face check in ValidateTopology (Sandro Santilli)</para>
+             <para>#4944, Side-location conflict check in ValidateTopology (Sandro Santilli)</para>
+             <para>#3042, ValidateTopology check for edge linking (Sandro Santilli)</para>
+             <para>#3276, ValidateTopology check for face's mbr (Sandro Santilli)</para>
+             <para>#4936, Bounding box limited ValidateTopology (Sandro Santilli)</para>
+             <para>#4933, Speed up topology building in presence of big faces (Sandro Santilli)</para>
+             <para>#3233, ValidateTopology check for node's containing_face (Sandro Santilli)</para>
+             <para>#4830, ValidateTopology check for edges side face containment
+             <para>#4827, Allow NaN coordinates in WKT input (Paul Ramsey)</para>
+             <para>ST_Value() accepts resample parameter to add bilinear option (Paul Ramsey)</para>
+             <para>#3778, #4401, ST_Boundary now works for TIN and does not linearize curves (Aliaksandr Kalenik)</para>
+             <para>#4881, #4884, Store sign of edge_id for lineal TopoGeometry in relation table
+                        to retain direction (Sandro Santilli)</para>
+             <para>#4628, Add an option to disable ANALYZE when loading shapefiles (Stefan Corneliu Petrea)</para>
+             <para>#4924, Faster ST_RemoveRepeatedPoints on large multipoints, O(NlogN) instead of O(N^2)
+                        (Aliaksandr Kalenik, Darafei Praliaskouski)</para>
+             <para>#4925, fix ST_DumpPoints to not overlook points (Aliaksandr Kalenik)</para>
+             <para>ST_SRID(topogeometry) override, to speedup lookups (Sandro Santilli)</para>
+             <para>#2175, Avoid creating additional nodes when adding same closed
+                        line to topology (Sandro Santilli)</para>
+             <para>#4974, Upgrade path for address_standardizer_data_us
+                        (Jan Katins of Aiven, Regina Obe)</para>
+             <para>#4975, PostGIS upgrade change to not use temp tables (Jan Katins of Aiven)</para>
+             <para>#4981, ST_StartPoint support any geometry (Aliaksandr Kalenik)</para>
+             <para>#4799, Include srs in GeoJSON where it exists in spatial_ref_sys.</para>
+             <para>#4986, GIST indexes on Postgres 14 are now created faster using Hilbert-sorting method.
+                        (Han Wang, Aliaksandr Kalenik, Darafei Praliaskouski, Giuseppe Broccolo)</para>
+             <para>#4949, Use proj_normalize_for_visualization to hand "axis swap" decisions (Paul Ramsey)</para>
+        </simplesect>
+        <simplesect>
+             <title>New features</title>
+                <para>#4923, topology.ValidateTopologyRelation (Sandro Santilli)</para>
+                <para>#4933, topology.GetFaceContainingPoint (Sandro Santilli)</para>
+                <para>#2175, ST_Scroll (Sandro Santilli)</para>
+                <para>#4841, FindTopology to quickly get a topology record (Sandro Santilli)</para>
+                <para>#4869, FindLayer to quickly get a layer record (Sandro Santilli)</para>
+                <para>#4851, TopoGeom_addTopoGeom function (Sandro Santilli)</para>
+                <para>ST_MakeValid(geometry, options) allows alternative validity building
+                    algorithms with GEOS 3.10 (Paul Ramsey)</para>
+                <para>ST_InterpolateRaster() fills in raster cells between sample points
+                    using one of a number of algorithms (inverse weighted distance, average, etc)
+                    using algorithms from GDAL
+                    (Paul Ramsey)</para>
+               <para>ST_Contour() generates contour lines from raster values
+                    using algorithms from GDAL (Paul Ramsey)</para>
+                <para>ST_SetZ()/ST_SetM() fills in z/m coordinates of a geometry using data read
+                    from a raster (Paul Ramsey)</para>
+                <para>New postgis.gdal_vsi_options GUC allows out-db rasters on VSI network
+                    services to be accessed with authentication keys, etc. (Paul Ramsey)</para>
+                <para>ST_DumpSegments returns a set of segments of input geometry (Aliaksandr Kalenik)</para>
+                <para>#4859, ST_Point, ST_PointZ, ST_PointM, ST_PointZM, constructors
+                    with SRID parameter (Paul Ramsey)</para>
+                <para>#4808, ST_ClusterKMeans now supports max_radius argument. Use it when you're not sure what is
+                    the number of clusters but you know what the size of clusters should be. (Darafei Praliaskouski)</para>
+        </simplesect>
+    </sect1>
+    <sect1>
         <title>Release 3.1.0beta1</title>
         <para>Release date: 2020/12/09</para>
         <para>Only changes since 3.1.0alpha2 are listed.
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 4674adb..639d1cd 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -66,4 +66,5 @@ UPGRADEABLE_VERSIONS = \
 	3.1.2	\
 	3.1.3 \
 	3.1.4 \
-	3.1.5dev
+	3.1.5dev \
+	3.2.0dev
Summary of changes:
 NEWS                               |  7 ++-
 Version.config                     |  2 +-
 doc/release_notes.xml              | 89 ++++++++++++++++++++++++++++++++++++++
 extensions/upgradeable_versions.mk |  3 +-
 4 files changed, 97 insertions(+), 4 deletions(-)
hooks/post-receive
