[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0alpha1-1-g3083021
Sat Sep 11 11:19:21 PDT 2021
the project "PostGIS".
       via  3083021ce2e170e0e76cf0408033c18c9bec3787 (commit)
      from  e357e0a7381a8c2f36c62375380acbf800da697d (commit)
revisions in full, below.
commit 3083021ce2e170e0e76cf0408033c18c9bec3787
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Sep 11 14:19:15 2021 -0400
    Flip back to dev mode and fix HOWTO_RELEASE instructions
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 676ffc1..16c5797 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -98,7 +98,7 @@ Release procedure
   - Commit all changes
   - If this is a minor or major release (no branch exists):
 	   $ rev=x.x
-	   $ git checkout main; git checkout -b "$rev"; git push -u osgeo $rev
+	   $ git checkout master; git checkout -b "$rev"; git push -u osgeo $rev
 	   Go to: https://debbie.postgis.net and copy last branch version and make new job
 	   a) Replace PostGIS_* string params with new version
diff --git a/NEWS b/NEWS
index 2db6651..7f3f090 100644
--- a/NEWS
+++ b/NEWS
@@ -1,8 +1,5 @@
-PostGIS 3.2.0alpha1
-2021/09/10
-This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
-Additional features are enabled if you are running GEOS 3.9+, Proj 6.1+, and PostgreSQL 14+.
+PostGIS 3.2.0
+2021/xx/xx
  * Breaking changes *
   - #4824, Removed `--without-wagyu` build option. Using Wagyu is now mandatory to build with MVT support.
@@ -83,9 +80,11 @@ Additional features are enabled if you are running GEOS 3.9+, Proj 6.1+, and Pos
   - #4808, ST_ClusterKMeans now supports max_radius argument. Use it when you're not sure what is
     the number of clusters but you know what the size of clusters should be. (Darafei Praliaskouski)
+PostGIS 3.2.0alpha1
+2021/09/10
-PostGIS 3.2.0
-2021/xx/xx
+This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9+, Proj 6.1+, and PostgreSQL 14+.
diff --git a/Version.config b/Version.config
index a29d574..843963a 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=0alpha1
+POSTGIS_MICRO_VERSION=0dev
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 639d1cd..b040a45 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -67,4 +67,4 @@ UPGRADEABLE_VERSIONS = \
 	3.1.3 \
 	3.1.4 \
 	3.1.5dev \
-	3.2.0dev
+	3.2.0alpha1
Summary of changes:
 HOWTO_RELEASE                      |  2 +-
 NEWS                               | 13 ++++++-------
 Version.config                     |  2 +-
 extensions/upgradeable_versions.mk |  2 +-
 4 files changed, 9 insertions(+), 10 deletions(-)
hooks/post-receive
