[postgis-tickets] [PostGIS] #4995: regress/loader/MultiPoint test is racy
PostGIS trac at osgeo.org
Thu Sep 16 22:53:52 PDT 2021
 Reporter:  Bas Couwenberg  |      Owner:  robe
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 3.1.5
Component:  loader/dumper   |    Version:  3.1.x
 Keywords:                  |
 Some loader tests are racy, they sometimes fail with:
 ERROR:  relation "loadedshp" already exists
 armhf example (package build on buildd):
  ./regress/loader/MultiPoint ............ failed (wkb testdiff expected
 obtained: /tmp/pgis_reg/test_116_diff)
 --- ./regress/loader/MultiPoint.select.expected 2021-09-04
 05:03:43.000000000 +0000
 +++ /tmp/pgis_reg/test_116_out  2021-09-17 03:06:56.245881317 +0000
 @@ -1 +0,0 @@
 -MULTIPOINT(0 1,9 -1,9 -1)
  ./regress/loader/MultiPointM ... failed ( wkt test: running shp2pgsql
 output: /tmp/pgis_reg/loader.err)
 SET
 SET
 BEGIN
 psql:/tmp/pgis_reg/loader.out:4: ERROR:  relation "loadedshp" already
 exists
  ./regress/loader/MultiPointZ ... failed ( wkt test: running shp2pgsql
 SET
 SET
 BEGIN
 exists
  ./regress/loader/Arc ... failed ( wkt test: running shp2pgsql output:
 SET
 SET
 BEGIN
 psql:/tmp/pgis_reg/loader.out:5: ERROR:  relation "loadedshp" already
 exists
  ./regress/loader/ArcM ... failed ( wkt test: running shp2pgsql output:
 SET
 SET
 BEGIN
 exists
  ./regress/loader/ArcZ ... failed ( wkt test: running shp2pgsql output:
 SET
 SET
 BEGIN
 exists
  ./regress/loader/Polygon ... failed ( wkt test: running shp2pgsql output:
 SET
 SET
 BEGIN
 exists
  ./regress/loader/PolygonM ... failed ( wkt test: running shp2pgsql
 SET
 SET
 BEGIN
 exists
  ./regress/loader/PolygonZ ... failed ( wkt test: running shp2pgsql
 SET
 SET
 BEGIN
 exists
  ./regress/loader/TSTPolygon ... failed ( wkt test: running shp2pgsql
 SET
 SET
 BEGIN
 exists
  ./regress/loader/TSIPolygon ... failed ( wkt test: running shp2pgsql
 SET
 SET
 BEGIN
 exists
  ./regress/loader/TSTIPolygon ... failed ( wkt test: running shp2pgsql
 SET
 SET
 BEGIN
 exists
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=armel&ver=3.1.4%2Bdfsg-1%2Bb2&stamp=1631848521&raw=0
 Full buildlog]
 i386 example (!GitLab CI Pipeline):
  ./regress/loader/PolygonM ............ failed (wkb testdiff expected
 obtained: /tmp/pgis_reg/test_123_diff)
 --- ./regress/loader/PolygonM.select.expected   2021-09-08
 15:38:20.000000000 +0000
 +++ /tmp/pgis_reg/test_123_out  2021-09-08 15:50:21.797366851 +0000
 @@ -1 +0,0 @@
 -MULTIPOLYGONM(((0 0 1,0 10 7,10 10 5,10 0 3,0 0 1),(5 5 9,8 5 15,8 8 13,5
 8 11,5 5 9)),((-1 -1 -1,-1 -10 -7,-10 -10 -5,-10 -1 -3,-1 -1 -1),(-5 -5
 -9,-8 -5 -15,-8 -8 -13,-5 -8 -11,-5 -5 -9)))
 SET
 SET
 BEGIN
 exists
 SET
 SET
 BEGIN
 exists
 SET
 SET
 BEGIN
 exists
 SET
 SET
 BEGIN
 exists
 [https://salsa.debian.org/debian-gis-team/postgis/-/jobs/1925038/raw Full
 buildlog]
 Retrying the build generally fixes the issue point to a race condition
 with the parallel builds.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4995>
