[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0alpha1-6-gc140fdb
Tue Sep 21 07:22:31 PDT 2021
the project "PostGIS".
       via  c140fdb8ca581d47b9173f3bbef61b75e6c26deb (commit)
      from  97139b6e803b0588b64497cd1c60d47abb30572a (commit)
revisions in full, below.
commit c140fdb8ca581d47b9173f3bbef61b75e6c26deb
Author: Björn Harrtell <bjorn at wololo.org>
Date:   Tue Sep 21 16:21:42 2021 +0200
    Consider empty geometry (fixes #4999)
diff --git a/deps/flatgeobuf/flatgeobuf_c.cpp b/deps/flatgeobuf/flatgeobuf_c.cpp
index 61d9dbc..dd87696 100644
--- a/deps/flatgeobuf/flatgeobuf_c.cpp
+++ b/deps/flatgeobuf/flatgeobuf_c.cpp
@@ -112,7 +112,7 @@ int flatgeobuf_encode_feature(ctx *ctx)
     Offset<Geometry> geometry = 0;
     Offset<Vector<uint8_t>> properties = 0;
-    if (ctx->lwgeom != NULL) {
+    if (ctx->lwgeom != NULL && !lwgeom_is_empty(ctx->lwgeom)) {
         LWDEBUGG(3, ctx->lwgeom, "GeometryWriter input LWGEOM");
         GeometryWriter writer(fbb, ctx->lwgeom, (GeometryType) ctx->geometry_type, ctx->has_z, ctx->has_m);
         geometry = writer.write(0);
@@ -142,11 +142,14 @@ int flatgeobuf_encode_feature(ctx *ctx)
     if (ctx->create_index) {
         auto item = (flatgeobuf_item *) lwalloc(sizeof(flatgeobuf_item));
-        auto gbox = lwgeom_get_bbox(ctx->lwgeom);
-        item->xmin = gbox->xmin;
-        item->xmax = gbox->xmax;
-        item->ymin = gbox->ymin;
-        item->ymax = gbox->ymax;
+        memset(item, 0, sizeof(flatgeobuf_item));
+            auto gbox = lwgeom_get_bbox(ctx->lwgeom);
+            item->xmin = gbox->xmin;
+            item->xmax = gbox->xmax;
+            item->ymin = gbox->ymin;
+            item->ymax = gbox->ymax;
         item->offset = ctx->offset;
         item->size = size;
         ctx->items[ctx->features_count] = item;
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index d89875f..e324f80 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -36,6 +36,10 @@ select 'P4', id, ST_AsEWKT(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
 select 'P5', id, ST_AsEWKT(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
     select ST_AsFlatGeobuf(q, true) fgb from (select ST_SetSRID(ST_MakePoint(-71.1043443253471, 42.3150676015829),4326)) q)
+-- Empty Point
+select 'P6', id, ST_AsEWKT(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
+    select ST_AsFlatGeobuf(q, true) fgb from (select ST_GeomFromText('POINT EMPTY')) q)
 -- 2D LineString
 select 'L1', id, ST_AsText(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
diff --git a/regress/core/flatgeobuf_expected b/regress/core/flatgeobuf_expected
index 0087d1d..4d1b4b3 100644
--- a/regress/core/flatgeobuf_expected
+++ b/regress/core/flatgeobuf_expected
@@ -6,6 +6,7 @@ P2|0|POINT Z (1.1 2.11 3.2)
 P3|0|POINT ZM (1.1 2.12 3.2 4.3)
 P4|0|SRID=4326;POINT(-71.1043443253471 42.3150676015829)
 P5|0|SRID=4326;POINT(-71.1043443253471 42.3150676015829)
+P6|0|
 L1|0|LINESTRING(1 2,3 4)
 L2|0|LINESTRING Z (1 2 3,3 4 5)
 L3|0|LINESTRING ZM (1 2 3 5,3 4 5 6)
Summary of changes:
 deps/flatgeobuf/flatgeobuf_c.cpp | 15 +++++++++------
 regress/core/flatgeobuf.sql      |  4 ++++
 regress/core/flatgeobuf_expected |  1 +
 3 files changed, 14 insertions(+), 6 deletions(-)
hooks/post-receive
