[postgis-tickets] [PostGIS] #4990: getfacecontainingpoint fails on i386
PostGIS trac at osgeo.org
Wed Sep 22 12:57:12 PDT 2021
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.2.0
 Component:  topology        |    Version:  master
Resolution:                  |   Keywords:
Comment (by strk):
 Merge request https://gitlab.com/postgis/postgis/-/merge_requests/58
 contains a partial change to avoid unaligned reads to at least the
 computed shortestLine. I think there are more possible unaligned reads BUT
 they could all be made against unserialized geoms which should be safe.
 Bas can you test that ?
 I wonder if we should provide alignment macros to ensure all our LWGEOMs
 are aligned no matter what... At least I say PostgreSQL source code making
 use of such macros for their code
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4990#comment:9>
