[postgis-tickets] [PostGIS] #4990: getfacecontainingpoint fails on i386
PostGIS trac at osgeo.org
Sun Sep 26 12:01:58 PDT 2021
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.2.0
 Component:  topology        |    Version:  master
Resolution:                  |   Keywords:
Comment (by strk):
 Ok something is definitely fishy here. Adding a debug line in ptarray.c
 changes results so that the closest segment is reported as being 0 instead
 of 1. With just this patch:
 diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
 index 7994d60dd..fe23282ea 100644
 --- a/liblwgeom/ptarray.c
 +++ b/liblwgeom/ptarray.c
 @@ -29,7 +29,7 @@
  #include <stdlib.h>
  #include "../postgis_config.h"
 -/*#define POSTGIS_DEBUG_LEVEL 4*/
 +#define POSTGIS_DEBUG_LEVEL 4
  #include "liblwgeom_internal.h"
  #include "lwgeom_log.h"
 @@ -1308,6 +1308,7 @@ ptarray_closest_segment_2d(const POINTARRAY *pa,
 const POINT2D *qp, double *dist
                 double dist_sqr;
                 end = getPoint2d_cp(pa, t);
                 dist_sqr = distance2d_sqr_pt_seg(qp, start, end);
 +               LWDEBUGF(3, "Sqr distance from seg %d: %g", t-1,
 dist_sqr);
                 if (dist_sqr < mindist)
 I guess it's time to valgrind the liblwgeom side of this
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4990#comment:25>
