[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0alpha1-31-g7db04ad
Mon Sep 27 03:48:09 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  7db04adfb58750da9978ebec2d56fec6d1392913 (commit)
      from  38b77f3a01788c1e0755fd49bc45ee4ace8c1cef (commit)
revisions in full, below.
commit 7db04adfb58750da9978ebec2d56fec6d1392913
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 27 12:47:56 2021 +0200
    Do not mix signedness of integers
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index b8216eb..97e0515 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -7059,9 +7059,9 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
   uint64_t numedges, i;
   const POINT2D *queryPoint;
   const POINT2D *closestPointOnEdge = NULL;
-  int closestSegmentIndex;
+  uint32_t closestSegmentIndex;
   int closestSegmentSide;
-  int closestPointVertex = -1;
+  uint32_t closestPointVertex;
   const POINT2D *closestSegmentP0, *closestSegmentP1;
   LWT_ELEMID closestNode = 0;
   double dist;
@@ -7139,6 +7139,10 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
       closestNode = closestEdge->end_node;
+  else
+    closestPointVertex = closestEdge->geom->points->npoints;
   if ( closestNode != 0 )
@@ -7243,7 +7247,7 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
   /* Find on which side of the segment the query point lays */
-  if ( closestPointVertex != -1 )
+  if ( closestPointVertex != closestEdge->geom->points->npoints )
     /* Closest point is a vertex of the closest segment */
     LWDEBUGF(1, "Closest point is vertex %d of closest segment", closestPointVertex);
@@ -7257,31 +7261,31 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
      * means the query point is on the right)
-    int prevVertexIndex = closestPointVertex > 0 ?
-      closestPointVertex - 1 :
-      closestEdge->geom->points->npoints - 2; /* last vertex would be == first vertex, this being a closed edge */
+    uint32_t prevVertexIndex = closestPointVertex > 0 ?
+      closestPointVertex - 1u :
+      closestEdge->geom->points->npoints - 2u; /* last vertex would be == first vertex, this being a closed edge */
     const POINT2D *prevVertex = getPoint2d_cp(
       closestEdge->geom->points,
       prevVertexIndex
-    LWDEBUGF(1, "Previous vertex %d is POINT(%.15g %.15g)",
+    LWDEBUGF(1, "Previous vertex %u is POINT(%.15g %.15g)",
       prevVertexIndex,
       prevVertex->x,
       prevVertex->y
-    int nextVertexIndex = closestPointVertex == closestEdge->geom->points->npoints - 1 ?
-      1 : /* first point would be == last point, this being a closed edge */
-      closestPointVertex + 1;
+    uint32_t nextVertexIndex = closestPointVertex == closestEdge->geom->points->npoints - 1u ?
+      1u : /* first point would be == last point, this being a closed edge */
+      closestPointVertex + 1u;
     const POINT2D *nextVertex = getPoint2d_cp(
       nextVertexIndex
-    LWDEBUGF(1, "Next vertex %d is POINT(%.15g %.15g)",
+    LWDEBUGF(1, "Next vertex %u is POINT(%.15g %.15g)",
       nextVertexIndex,
       nextVertex->x,
       nextVertex->y
Summary of changes:
 liblwgeom/lwgeom_topo.c | 26 +++++++++++++++-----------
 1 file changed, 15 insertions(+), 11 deletions(-)
hooks/post-receive
