[postgis-tickets] [PostGIS] #5002: liblwgeom builds with no warning flags by default
PostGIS trac at osgeo.org
Mon Sep 27 09:02:30 PDT 2021
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.2.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by strk):
 * cc: Algunenano (added)
Comment:
 Algunenano do you agree to re-add -Wall to CFLAGS ?
 I guess we used a DIFFERENT variable to avoid having duplicated flags when
 building the PostgreSQL-dependent code which already uses flags from
 PostgreSQL build
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5002#comment:3>
