[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0alpha1-37-g016b911
Tue Sep 28 03:06:23 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  016b9115eb87b3d3b46e009d8e78aa873a829890 (commit)
      from  f1f145c6c1030a4f66daeb127b378930d9f8dfee (commit)
revisions in full, below.
commit 016b9115eb87b3d3b46e009d8e78aa873a829890
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Sep 28 12:05:16 2021 +0200
    run_test.pl: avoid loader test failure breaking subsequent tests
    Closes #4995
    Still keeps the loadedshp table on failure if --nodrop is given
diff --git a/regress/run_test.pl b/regress/run_test.pl
index d7282df..a7372b2 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1053,6 +1053,7 @@ sub run_loader_test
 	# If we have some expected files to compare with, run in wkt mode.
 	if ( ! run_loader_and_check_output("wkt test", $tblname, "${TEST}-w.sql.expected", "${TEST}-w.select.expected", "-w $custom_opts") )
+		drop_table($tblname) unless $OPT_NODROP;
 		return 0;
 	drop_table($tblname);
@@ -1060,11 +1061,13 @@ sub run_loader_test
 	# If we have some expected files to compare with, run in geography mode.
 	if ( ! run_loader_and_check_output("geog test", $tblname, "${TEST}-G.sql.expected", "${TEST}-G.select.expected", "-G $custom_opts") )
 		return 0;
 	# If we have some expected files to compare with, run the dumper and compare shape files.
 	if ( ! run_dumper_and_check_output("dumper geog test", $tblname, "${TEST}-G.shp.expected") )
 		return 0;
@@ -1072,11 +1075,13 @@ sub run_loader_test
 	# Always run in wkb ("normal") mode, even if there are no expected files to compare with.
 	if( ! run_loader_and_check_output("wkb test", $tblname, "${TEST}.sql.expected", "${TEST}.select.expected", "$custom_opts", "true") )
 		return 0;
 	if( ! run_dumper_and_check_output("dumper wkb test", $tblname, "${TEST}.shp.expected") )
 		return 0;
@@ -1087,6 +1092,7 @@ sub run_loader_test
 		# If we have some expected files to compare with, run in wkt dump mode.
 		if ( ! run_loader_and_check_output("wkt dump test", $tblname, "${TEST}-wD.sql.expected") )
 			return 0;
@@ -1094,6 +1100,7 @@ sub run_loader_test
 		if ( ! run_loader_and_check_output("geog dump test", $tblname, "${TEST}-GD.sql.expected") )
 			return 0;
@@ -1101,6 +1108,7 @@ sub run_loader_test
 		# If we have some expected files to compare with, run in wkb dump mode.
 		if ( ! run_loader_and_check_output("wkb dump test", $tblname, "${TEST}-D.sql.expected") )
 			return 0;
Summary of changes:
 regress/run_test.pl | 8 ++++++++
 1 file changed, 8 insertions(+)
hooks/post-receive
