[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0alpha1-42-gf075d02
Wed Sep 29 07:05:43 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  f075d028c0988a9f7b000211901a099618bae537 (commit)
      from  066e0de515337a503fe848c18cb928b77c96964f (commit)
revisions in full, below.
commit f075d028c0988a9f7b000211901a099618bae537
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 29 16:05:22 2021 +0200
    Add documentation for ST_Scroll
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 96f37c8..719b46e 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -425,6 +425,52 @@ st_astext
       </refsection>
     </refentry>
+    <refentry id="ST_Scroll">
+      <refnamediv>
+        <refname>ST_Scroll</refname>
+        <refpurpose>Change start point of a closed LineString.</refpurpose>
+      </refnamediv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_Scroll</function></funcdef>
+            <paramdef><type>geometry</type> <parameter>linestring</parameter></paramdef>
+            <paramdef><type>geometry</type> <parameter>point</parameter></paramdef>
+          </funcprototype>
+         </funcsynopsis>
+      </refsynopsisdiv>
+      <refsection>
+        <title>Description</title>
+        <para>
+Changes the start/end point of a closed LineString to
+the given vertex <parameter>point</parameter>.
+        </para>
+        <para>Availability: 3.2.0</para>
+        <para>&Z_support;</para>
+        <para>&M_support;</para>
+      </refsection>
+      <refsection>
+        <title>Examples</title>
+        <para>Make e closed line start at its 3rd vertex</para>
+<programlisting>
+SELECT ST_AsEWKT(ST_Scroll('SRID=4326;LINESTRING(0 0 0 1, 10 0 2 0, 5 5 4 2,0 0 0 1)', 'POINT(5 5 4 2)'));
+st_asewkt
+SRID=4326;LINESTRING(5 5 4 2,0 0 0 1,10 0 2 0,5 5 4 2)
+</programlisting>
+      </refsection>
+      <refsection>
+        <title>See Also</title>
+        <para><xref linkend="ST_Normalize"/>, <xref linkend="ST_Normalize" /></para>
+      </refsection>
+</refentry>
     <refentry id="ST_FlipCoordinates">
       <refnamediv>
         <refname>ST_FlipCoordinates</refname>
diff --git a/regress/core/scroll.sql b/regress/core/scroll.sql
index 113054c..1de9165 100644
--- a/regress/core/scroll.sql
+++ b/regress/core/scroll.sql
@@ -5,3 +5,9 @@ SELECT ST_Scroll('LINESTRING(0 0, 10 0, 5 5)', 'POINT(0 0)');
 SELECT ST_AsEWKT(ST_Scroll('SRID=4326;LINESTRING(0 0, 10 0, 5 5,0 0)', 'POINT(0 0)'));
 SELECT ST_AsEWKT(ST_Scroll('SRID=4326;LINESTRING(0 0, 10 0, 5 5,0 0)', 'POINT(5 5)'));
 SELECT ST_AsEWKT(ST_Scroll('SRID=4326;LINESTRING(0 0, 10 0, 5 5,0 0)', 'POINT(10 0)'));
+SELECT ST_AsEWKT(ST_Scroll('SRID=4326;LINESTRINGM(0 0 0, 10 0 2, 5 5 4,0 0 0)', 'POINT(10 0 2)'));
+SELECT ST_AsEWKT(ST_Scroll('SRID=4326;LINESTRINGZ(0 0 0, 10 0 2, 5 5 4,0 0 0)', 'POINT(5 5 4)'));
diff --git a/regress/core/scroll_expected b/regress/core/scroll_expected
index 7a0d0e8..de0043b 100644
--- a/regress/core/scroll_expected
+++ b/regress/core/scroll_expected
@@ -4,3 +4,6 @@ ERROR:  ptarray_scroll_in_place: input POINTARRAY is not closed
 SRID=4326;LINESTRING(0 0,10 0,5 5,0 0)
 SRID=4326;LINESTRING(5 5,0 0,10 0,5 5)
 SRID=4326;LINESTRING(10 0,5 5,0 0,10 0)
+SRID=4326;LINESTRINGM(10 0 2,5 5 4,0 0 0,10 0 2)
+SRID=4326;LINESTRING(5 5 4,0 0 0,10 0 2,5 5 4)
Summary of changes:
 doc/reference_editor.xml     | 46 ++++++++++++++++++++++++++++++++++++++++++++
 regress/core/scroll.sql      |  6 ++++++
 regress/core/scroll_expected |  3 +++
 3 files changed, 55 insertions(+)
hooks/post-receive
