[postgis-tickets] [PostGIS] #5122: Crash on aurora postgres topology add_polygon
PostGIS trac at osgeo.org
Fri Apr 1 09:16:12 PDT 2022
  Reporter:  robe      |      Owner:  robe
      Type:  defect    |     Status:  assigned
  Priority:  medium    |  Milestone:  PostGIS 3.1.6
 Component:  topology  |    Version:  3.1.x
Resolution:            |   Keywords:
Comment (by robe):
 I should add, to rule out 3.1.5 as the culprit, I built on my mingw 3.1.5
 and tested against 3.1.5, and that worked fine.  So I'm suspecting it's my
 sizing of aurora instance I screwed up or something about the aurora
 special storage structure causing the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5122#comment:1>
