[postgis-tickets] [PostGIS] #5121: winnie is broken with this strange error lto1.exe: internal compiler error: in gen_subprogram_die, at dwarf2out.c:22668
PostGIS trac at osgeo.org
Fri Apr 1 09:52:50 PDT 2022
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.3.0
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by robe):
 Okay tested on my mingw setup (my setup is old BTW gcc 8.1 but that is
 another story)
 At anyrate the patch seems to screw up ability to find CC.
 cc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Werror=vla -Wendif-labels -Wmissing-format-attribute
 -Wimplicit-fallthrough=3 -Wcast-function-type -Wformat-security -fno-
 strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation
 -Wno-stringop-truncation -g -O2  -I../liblwgeom -I../liblwgeom -std=gnu99
 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -flto -I../libpgcommon
 -I../deps/flatgeobuf -I../deps/wagyu -I../deps/uthash/include
 -I/projects/geos/rel-3.11w64gcc81/include
 -IC:/ming64gcc81/projects/proj/rel-7.2.1w64gcc81/include
 -IC:/ming64gcc81/projects/protobuf/rel-3.2.0w64gcc81/include
 -I/projects/libxml/rel-libxml2-2.9.9w64gcc81/include/libxml2
 -I/projects/CGAL/rel-sfcgal-1.4.0w64gcc81/include
 -IC:/ming64gcc81/projects/json-c/rel-0.12w64gcc81/include/json-c
 -IC:/ming64gcc81/projects/pcre/rel-8.33w64gcc81/include   -DNDEBUG
 -I/projects/postgresql/rel/pg15w64gcc81/include -I/projects/rel-
 libiconv-1.16w64gcc81/include  -DDLL_EXPORT -DPIC -I. -I./
 -IC:/MING64~1/projects/POSTGR~1/rel/PG15W6~1/include/server
 -IC:/MING64~1/projects/POSTGR~1/rel/PG15W6~1/include/internal
 -I/projects/zlib/rel-zlib-1.2.11w64gcc81/include  -I/projects/libxml/rel-
 libxml2-2.9.9w64gcc81/include -I./src/include/port/win32
 -IC:/ming64gcc81/projects/lz4/rel-lz4-1.9.3w64gcc81/include
 -IC:/MING64~1/projects/POSTGR~1/rel/PG15W6~1/include/server/port/win32
 -DWIN32_STACK_RLIMIT=4194304  -c -o postgis_module.o postgis_module.c
 /bin/sh: line 1: cc: command not found
 Looking at the postgis/Makefile generated, it seems to have
 CUSTOM_CC := $(CC)
 Which I am assuming is the culprit.  By comparison, the generated
 liblwgeom/Makefile has
 CC = x86_64-w64-mingw32-gcc
 trying to change Makefile.in to below gets me back to the original error
 CUSTOM_CC := @CC@
 FWIW I think @strk was saying we should get rid of PGXS as it's causing
 more issues than helping.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5121#comment:3>
