[postgis-tickets] [SCM] postgis.net branch website updated. 34a6e0eaff3e460d75cca37756db5cefef5debb9
Mon Apr 4 14:19:35 PDT 2022
the project "postgis.net".
The branch, website has been updated
       via  34a6e0eaff3e460d75cca37756db5cefef5debb9 (commit)
      from  860b5629fad4f6c37998542a97a6663840fd9560 (commit)
revisions in full, below.
commit 34a6e0eaff3e460d75cca37756db5cefef5debb9
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Apr 4 23:19:26 2022 +0200
    80 cols wrap
diff --git a/README.md b/README.md
index 26e39e3..0e855aa 100644
--- a/README.md
+++ b/README.md
@@ -1,22 +1,28 @@
 ## Static Site Build
-Our site is built with [hugo](https://gohugo.io/). To work with the docs you will probably want to [install hugo](https://gohugo.io/getting-started/installing/#quick-install) so you can see the rendered result as you work.
+Our site is built with [hugo](https://gohugo.io/).
+To work with the docs you will probably want to
+[install hugo](https://gohugo.io/getting-started/installing/#quick-install)
+so you can see the rendered result as you work.
 ## Theme
-This site is using [hugo-clarity](https://github.com/chipzoller/hugo-clarity) theme.
+This site is using
+[hugo-clarity](https://github.com/chipzoller/hugo-clarity) theme.
 ## Development
-Install the hugo binary for your operating system. Run the local server.
+Install the hugo binary for your operating system.
+Run the local server:
-hugo server
+    hugo server
-Remember to set "draft: false" in the page front matter or your content won't show up.
+Remember to set "draft: false" in the page front matter or your content
+won't show up.
 ## Building
-To build run hugo without any arguments. This will create a public folder.
-hugo
+To build run hugo without any arguments.
+This will create a public folder:
+    hugo
Summary of changes:
 README.md | 28 +++++++++++++++++-----------
 1 file changed, 17 insertions(+), 11 deletions(-)
hooks/post-receive
postgis.net
