[postgis-tickets] [PostGIS] #5123: PostgreSQL 15 build is broken - jsonb failures
PostGIS trac at osgeo.org
Tue Apr 5 19:07:24 PDT 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.3.0
 Component:  postgis  |    Version:  3.2.x
Resolution:  fixed    |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"6225a9a67e2bdaa749f1606389ea5af4e3b85099/git"
 6225a9a6/git]:
 #!CommitTicketReference repository="git"
 revision="6225a9a67e2bdaa749f1606389ea5af4e3b85099"
 Fix compile against PG15
 1. json. json and jsonb are now keywords so must be quoted as function
 names
 2. json functions now exposed in api so exclude from code for PG15.
 Closes #5123 for PostGIS 3.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5123#comment:5>
