[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-697-gb68342617
Wed Apr 6 02:03:18 PDT 2022
the project "PostGIS".
       via  b68342617e17bcdf800613d43b3a4fd2fe7dced5 (commit)
      from  83faf96fc252504ada28bd07ba86c4ba6b31aa5a (commit)
revisions in full, below.
commit b68342617e17bcdf800613d43b3a4fd2fe7dced5
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Mar 28 18:42:37 2022 +0200
    topology loader/dumper scripts
diff --git a/.editorconfig b/.editorconfig
index 9d91e6ff2..493a499d5 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -21,6 +21,10 @@ indent_style = tab
 [*.pl]
 indent_style = tab
+[topology/loader/*.sh]
+indent_style = space
+indent_size = 2
 # Exception: utils/postgis_proc_upgrade.pl uses 4-spaces indent
 [utils/postgis_proc_upgrade.pl]
diff --git a/NEWS b/NEWS
index 64fdb4664..0b5d355f7 100644
--- a/NEWS
+++ b/NEWS
@@ -23,6 +23,7 @@ PostGIS 3.3.0dev
   - GH678, Enable Link-Time Optimizations by default if supported (Sergei Shoulbakov)
  * New features *
+  - #5116, Topology export/import scripts (Sandro Santilli)
   - ST_Letters creates geometries that look like letters (Paul Ramsey)
   - #5037, postgis_sfcgal: ST_3DConvexHull (Loïc Bartoletti)
   - postgis_sfcgal: sfcgal_full_version - reports BOOST and CGAL version
diff --git a/topology/loader/pgtopo_export.sh b/topology/loader/pgtopo_export.sh
new file mode 100755
index 000000000..ccec86278
--- /dev/null
+++ b/topology/loader/pgtopo_export.sh
@@ -0,0 +1,209 @@
+#!/bin/sh
+# PostGIS - Spatial Types for PostgreSQL
+# http://postgis.net
+# Copyright (C) 2022 Sandro Santilli <strk at kbt.io>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU General Public Licence. See the COPYING file.
+set -e
+usage() {
+  echo "Usage: $0 [--skip-layers] [ -f <dumpfile> ] <dbname> <toponame>"
+SKIP_LAYERS=no
+OUTFILE=-
+while test -n "$1"; do
+  if test "$1" = '--skip-layers'; then
+    SKIP_LAYERS=yes
+    shift
+  elif test "$1" = '-f'; then
+    shift
+    OUTFILE=$1
+    shift
+  elif test -z "${DBNAME}"; then
+    DBNAME=$1
+    shift
+  elif test -z "${TOPONAME}"; then
+    TOPONAME=$1
+    shift
+  else
+    echo "Unrecognized option $1" >&2
+    usage >&2
+    exit 1
+  fi
+done
+DUMPNAME="pgtopo_export"
+if test "${OUTFILE}" = "-"; then
+  exec 4>&2
+else
+  exec 4>&1
+fi
+test -n "${TOPONAME}" || {
+  usage >&2
+  exit 1
+TMPDIR=${TMPDIR-/tmp}
+WORKDIR=${TMPDIR}/pgtopo_export_$$
+DUMPDIR=${WORKDIR}/${DUMPNAME}
+mkdir -p ${DUMPDIR}
+cleanup() {
+  echo "Cleaning up" >&4
+  rm -rf ${WORKDIR}
+trap 'cleanup' 0
+export PGDATABASE=${DBNAME}
+# Write version info (of the output format)
+echo "1" > ${DUMPDIR}/pgtopo_dump_version || exit 1
+# Save topology info
+echo "Exporting topology config..." >&4
+cat <<EOF | psql --set ON_ERROR_STOP=1 -XtA > ${DUMPDIR}/topology || exit 1
+COPY (
+  SELECT
+    srid,
+    precision,
+    hasz
+  FROM
+    topology.topology
+  WHERE name = '${TOPONAME}'
+TO STDOUT;
+EOF
+# Save layers info
+echo "Exporting layers info..." >&4
+cat <<EOF | psql --set ON_ERROR_STOP=1 -XtA > ${DUMPDIR}/layers || exit 1
+COPY (
+  SELECT
+    layer_id,
+    schema_name,
+    table_name,
+    feature_column,
+    feature_type,
+    level,
+    child_id
+  FROM
+    topology.layer l,
+    topology.topology t
+  WHERE
+    t.name = '${TOPONAME}'
+    AND l.topology_id = t.id
+TO STDOUT;
+EOF
+# Copy topology primitives
+# Nodes
+# Workaround for https://trac.osgeo.org/postgis/ticket/5102
+echo "Exporting node..." >&4
+cat <<EOF | psql --set ON_ERROR_STOP=1 -XtA > ${DUMPDIR}/node || exit 1
+COPY ( SELECT
+  node_id,
+  geom,
+  containing_face
+FROM ${TOPONAME}.node ) TO STDOUT;
+EOF
+# Edges
+# FIXME: copy edge view https://trac.osgeo.org/postgis/ticket/5119
+echo "Exporting edge..." >&4
+cat <<EOF | psql --set ON_ERROR_STOP=1 -XtA > ${DUMPDIR}/edge_data || exit 1
+COPY ( SELECT
+  edge_id,
+  start_node,
+  end_node,
+  next_left_edge,
+  abs_next_left_edge,
+  next_right_edge,
+  abs_next_right_edge,
+  left_face,
+  right_face,
+  geom
+FROM ${TOPONAME}.edge_data ) TO STDOUT;
+EOF
+# Faces
+echo "Exporting face..." >&4
+  cat <<EOF | psql --set ON_ERROR_STOP=1 -XtA > ${DUMPDIR}/face || exit 1
+COPY ( SELECT
+  face_id,
+  mbr
+FROM ${TOPONAME}.face WHERE face_id != 0 ) TO STDOUT;
+EOF
+# Relation
+echo "Exporting relation..." >&4
+  cat <<EOF | psql --set ON_ERROR_STOP=1 -XtA > ${DUMPDIR}/relation || exit 1
+COPY ( SELECT * FROM ${TOPONAME}.relation ) TO STDOUT;
+EOF
+if test "$SKIP_LAYERS" = "no"; then # {
+  # Dump layer tables
+  DUMPFILE="${DUMPDIR}/layers.dump"
+  CMD="pg_dump -O -x -Fc"
+  CMD="${CMD} -f ${DUMPFILE}"
+  exec 3< ${DUMPDIR}/layers
+  numlayers=0
+  while read -r line <&3; do
+    id=$(echo "${line}" | cut -f1)
+    schema=$(echo "${line}" | cut -f2)
+    table=$(echo "${line}" | cut -f3)
+    layer="\"${schema}\".\"${table}\""
+    #echo "Layer: ${layer}"
+    CMD="${CMD} -t ${layer}"
+    numlayers=$((numlayers+1))
+  done;
+  if test ${numlayers} -gt 0; then
+    echo "Dumping ${numlayers} layers..." >&4
+    #echo "Running ${CMD}" >&4
+    ${CMD} || exit 1
+  fi
+fi # }
+  if test "${OUTFILE}" != "-"; then
+    OFILE=$(cd $(dirname ${OUTFILE}) && pwd)/$(basename ${OUTFILE})
+  else
+    OFILE=-
+  fi
+  cd ${DUMPDIR}/.. || exit 1
+  echo "Archiving..." >&4
+  tar czf ${OFILE} ${DUMPNAME} || exit 1
+exit 0
diff --git a/topology/loader/pgtopo_import.sh b/topology/loader/pgtopo_import.sh
index 000000000..526ccd8c8
--- /dev/null
+++ b/topology/loader/pgtopo_import.sh
@@ -0,0 +1,314 @@
+#!/bin/sh
+set -e
+usage() {
+  echo "Usage: $0 [ --skip-layers | --only-layers ] [ -f <dumpfile> ] <toponame>"
+SKIP_LAYERS=no
+ONLY_LAYERS=no
+TOPONAME=
+DUMPFILE=-
+    SKIP_LAYERS=yes
+    shift
+  elif test "$1" = '--only-layers'; then
+    ONLY_LAYERS=yes
+    shift
+    shift
+    DUMPFILE="$1"
+    shift
+    TOPONAME=$1
+    shift
+  else
+    usage >&2
+    exit 1
+  fi
+done
+  usage >&2
+  exit 1
+if test "${SKIP_LAYERS}" = "yes" -a "${ONLY_LAYERS}" = "yes"; then
+  echo "--skip-layers conflicts with --only-layers" >&2
+  exit 1
+fi
+WORKDIR=${TMPDIR}/pgtopo_import_$$
+mkdir -p ${WORKDIR}
+cleanup() {
+  echo "Cleaning up" >&2
+  rm -rf ${WORKDIR}
+trap 'cleanup' 0
+# Uncompress the dumpfile
+tar xzf ${DUMPFILE} -C ${WORKDIR} >&2
+DUMPDIR="${WORKDIR}/pgtopo_export"
+test -d "${DUMPDIR}" || {
+  echo "Missing 'pgtopo_export' dir in export file zip" >&2
+  exit 1
+# Verify version
+DUMPVERSION=$(cat ${DUMPDIR}/pgtopo_dump_version)
+test ${DUMPVERSION} -eq '1' || {
+  echo "Unknown pgtopo dump version ${DUMPVERSION}" >&2
+  exit 1
+# Start a transaction
+echo "BEGIN;"
+if test "$ONLY_LAYERS" = "no"; then # {
+  # Create topology
+  TOPO_SRID=$(cut -f1 ${DUMPDIR}/topology)
+  TOPO_PREC=$(cut -f2 ${DUMPDIR}/topology)
+  TOPO_HASZ=$(cut -f3 ${DUMPDIR}/topology)
+  cat<<EOF
+  SELECT topology.CreateTopology(
+    '${TOPONAME}',
+    '${TOPO_SRID}',
+    '${TOPO_PREC}',
+    '${TOPO_HASZ}'
+EOF
+  # Load primitives data
+  # Load faces
+  cat <<EOF
+  COPY "${TOPONAME}".face (
+    face_id,
+    mbr
+  ) FROM STDIN;
+EOF
+  cat ${DUMPDIR}/face
+  echo "\\."
+  # Load nodes
+  cat <<EOF
+  COPY "${TOPONAME}".node (
+    node_id,
+    geom,
+    containing_face
+  ) FROM STDIN;
+EOF
+  cat ${DUMPDIR}/node
+  echo "\\."
+  # Load edges
+  cat <<EOF
+  COPY "${TOPONAME}".edge_data (
+    edge_id,
+    start_node,
+    end_node,
+    next_left_edge,
+    next_right_edge,
+    left_face,
+    right_face,
+    geom
+  ) FROM STDIN;
+EOF
+  cat ${DUMPDIR}/edge_data
+  echo "\\."
+  # Set id sequences of primitive tables
+  cat <<EOF
+    SELECT pg_catalog.setval(
+      '${TOPONAME}.node_node_id_seq',
+      max(node_id),
+      true
+    FROM "${TOPONAME}".node;
+      '${TOPONAME}.edge_data_edge_id_seq',
+      max(edge_id),
+      true
+    FROM "${TOPONAME}".edge_data;
+      '${TOPONAME}.face_face_id_seq',
+      NULLIF(max(face_id), 0),
+      true
+    FROM "${TOPONAME}".face;
+EOF
+fi # } ONLY_LAYERS != "no"
+  # Create schemas of layer tables, if any
+  for sch in $(cut -f2 ${DUMPDIR}/layers | sort -u); do
+    echo "CREATE SCHEMA IF NOT EXISTS \"${sch}\";"
+  done
+  # Restore all layer tables
+  if test -f ${DUMPDIR}/layers.dump; then
+    pg_restore -x -O -f - ${DUMPDIR}/layers.dump
+  fi
+  # Register topological layers
+    #echo "X LINE: ${line}" >&2
+    column=$(echo "${line}" | cut -f4)
+    typ=$(echo "${line}" | cut -f5)
+    level=$(echo "${line}" | cut -f6)
+    child=$(echo "${line}" | cut -f7)
+    #echo "X CHILD: ${child}" >&2
+    if test "${child}" = '\N'; then
+      child="null"
+    fi
+    #echo "CHILD: ${child}" >&2
+    cat <<EOF
+DO \$BODY\$
+DECLARE
+  t topology.topology;
+BEGIN
+  SELECT * FROM topology.topology
+  INTO STRICT t;
+  -- Register layer in topology.layer table
+  INSERT INTO topology.layer VALUES (
+    t.id,
+    ${id},
+    '${schema}',
+    '${table}',
+    '${column}',
+    ${typ},
+    ${level},
+    ${child}
+  -- Create and initialize layer's topogeometry sequence
+  CREATE SEQUENCE "${TOPONAME}".topogeo_s_${id};
+  PERFORM pg_catalog.setval(
+    '${TOPONAME}.topogeo_s_${id}',
+    max(id("${column}")),
+    true
+  FROM "${schema}"."${table}";
+  -- drop-constraint (should we not restore them at all instead?)
+  ALTER TABLE "${schema}"."${table}"
+  DROP CONSTRAINT IF EXISTS "check_topogeom_${column}";
+  -- update topology_id
+  UPDATE "${schema}"."${table}"
+  SET "${column}".topology_id = t.id;
+  -- re-create constraint (skip this?)
+  EXECUTE format(
+    \$STATEMENT\$
+      ADD CONSTRAINT "check_topogeom_${column}"
+      CHECK (
+        topology_id("${column}") = %1\$L
+        AND
+        layer_id("${column}") = ${id}
+        AND
+        type("${column}") = ${typ}
+    \$STATEMENT\$,
+    t.id
+END;
+\$BODY\$ LANGUAGE 'plpgsql';
+EOF
+  done;
+  # Update layer_id sequence
+  cat <<EOF
+    '${TOPONAME}.layer_id_seq',
+    max(l.layer_id),
+    true
+  FROM topology.layer l, topology.topology t
+  WHERE l.topology_id = t.id AND
+  t.name = '${TOPONAME}';
+EOF
+  # Load relation (after creating layers)
+  for tab in relation; do
+    cat <<EOF
+  COPY "${TOPONAME}".${tab} FROM STDIN;
+EOF
+    cat ${DUMPDIR}/${tab}
+    echo "\\."
+  done
+fi # } SKIP_LAYERS != "no"
+# Commit all
+echo "COMMIT;"
Summary of changes:
 .editorconfig                    |   4 +
 NEWS                             |   1 +
 topology/loader/pgtopo_export.sh | 209 ++++++++++++++++++++++++++
 topology/loader/pgtopo_import.sh | 314 +++++++++++++++++++++++++++++++++++++++
 4 files changed, 528 insertions(+)
 create mode 100755 topology/loader/pgtopo_export.sh
 create mode 100755 topology/loader/pgtopo_import.sh
hooks/post-receive
