[postgis-tickets] [PostGIS] #5121: LTO enabled causes windows, freebsd and some github actions to fail
PostGIS trac at osgeo.org
Thu Apr 7 01:57:11 PDT 2022
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.3.0
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by sergeish):
 Yes, github action errors seem not related at first glance. I decided to
 switch the breaking PR from draft because of that.
 Unfortunately I still don't have a fix. I'm going to proceed as if the
 plan is to get rid of PGXS and hopefully find some kind of solution in the
 process.
 Adding LTO flags automatically should probably be disabled for now.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5121#comment:13>
