[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.1-12-g874e93859
Thu Apr 7 08:06:39 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  874e93859fff27416b4f594a3ec4780f602e7e6a (commit)
      from  6225a9a67e2bdaa749f1606389ea5af4e3b85099 (commit)
revisions in full, below.
commit 874e93859fff27416b4f594a3ec4780f602e7e6a
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Apr 7 16:45:52 2022 +0200
    GRANT USAGE ON SCHEMA topology TO PUBLIC
    Closes #5124 in 3.2 branch (3.2.2dev)
diff --git a/NEWS b/NEWS
index b6d5c1ed7..fd39ee799 100644
--- a/NEWS
+++ b/NEWS
@@ -2,6 +2,7 @@ PostGIS 3.2.2dev
 2022/MM/DD
 * Bug Fixes *
+  - #5124, GRANT USAGE on topology schema to PUBLIC (Sandro Santilli)
   - #5120, Fix not-null result from ST_EstimatedExtent against
            truncated tables with spatial index (Sandro Santilli)
   - #5115, Allow dropping topologies with pending constraints
@@ -32,10 +33,9 @@ PostGIS 3.2.1
   - #5090, #5091 configure --with-protobuf-lib / --with-protobufdir
            , --without-protobuf broken (Tobias Bussmann)
 PostGIS 3.2.0 (Olivier Courtin Edition)
 2021/12/17
 This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher
 , and Proj 4.9+.
 Additional features are enabled if you are running GEOS 3.9+
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 897d42207..191e9da6b 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1853,5 +1853,7 @@ SELECT topology.AddToSearchPath('topology');
 -- See https://trac.osgeo.org/postgis/ticket/4575
 GRANT SELECT ON topology.topology TO PUBLIC;
 GRANT SELECT ON topology.layer TO PUBLIC;
+-- See https://trac.osgeo.org/postgis/ticket/5124
+GRANT USAGE ON SCHEMA topology TO PUBLIC;
 COMMIT;
Summary of changes:
 NEWS                     | 4 ++--
 topology/topology.sql.in | 2 ++
 2 files changed, 4 insertions(+), 2 deletions(-)
hooks/post-receive
