[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-705-g3dea38a65
Fri Apr 8 02:40:39 PDT 2022
the project "PostGIS".
       via  3dea38a651fa9c4538fd087df271a38af6f151bc (commit)
      from  8172be380d38c26fa3b501932a335a8803f23385 (commit)
revisions in full, below.
commit 3dea38a651fa9c4538fd087df271a38af6f151bc
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Apr 8 11:08:49 2022 +0200
    Do not undo search_path changes done by pgis exts in single session
    References #5125 in master branch (3.3.0dev)
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index 77ef0db74..fe6ed9ba9 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -109,7 +109,32 @@ DECLARE
 	var_result text;
 	var_cur_search_path text;
 BEGIN
-	SELECT reset_val INTO var_cur_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
+	WITH settings AS (
+		SELECT unnest(setconfig) config
+		FROM pg_catalog.pg_db_role_setting
+		WHERE setdatabase = (
+			SELECT oid
+			FROM pg_catalog.pg_database
+			WHERE datname = current_database()
+		) and setrole = 0
+	SELECT regexp_replace(c, '^search_path=', '')
+	FROM settings WHERE c like 'search_path=%'
+	INTO var_cur_search_path;
+	RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
+	IF var_cur_search_path IS NULL THEN
+		SELECT reset_val
+		FROM pg_catalog.pg_settings
+		WHERE name = 'search_path';
+		RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
+	END IF;
 	IF var_cur_search_path LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
 		var_result := a_schema_name || ' already in database search_path';
 	ELSE
Summary of changes:
 extensions/postgis_extension_helper.sql | 27 ++++++++++++++++++++++++++-
 1 file changed, 26 insertions(+), 1 deletion(-)
hooks/post-receive
