[postgis-tickets] [PostGIS] #5129: bessies crashing arbitrarily
PostGIS trac at osgeo.org
Mon Apr 11 08:32:55 PDT 2022
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  high       |  Milestone:  PostGIS 3.3.0
Component:  buildbots  |    Version:  master
 Keywords:             |
 I suspect this might be something amiss with the vms.  Beofre it was just
 bessie32 crashing now both are crashing in random spots.
 on bessie
 04:16:50  ./regress/core/node .. ok in 231 ms
 04:16:50  ./regress/core/unaryunion ..FATAL: command execution failed
 04:23:55 java.io.EOFException
 04:23:55        at
 java.base/java.io.ObjectInputStream$PeekInputStream.readFully(ObjectInputStream.java:2905)
 04:23:55        at
 java.base/java.io.ObjectInputStream$BlockDataInputStream.readShort(ObjectInputStream.java:3400)
 04:23:55        at
 java.base/java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:936)
 04:23:55        at
 java.base/java.io.ObjectInputStream.<init>(ObjectInputStream.java:379)
 04:23:55        at
 hudson.remoting.ObjectInputStreamEx.<init>(ObjectInputStreamEx.java:49)
 04:23:55        at hudson.remoting.Command.readFrom(Command.java:142)
 04:23:55        at hudson.remoting.Command.readFrom(Command.java:128)
 04:23:55        at
 hudson.remoting.AbstractSynchronousByteArrayCommandTransport.read(AbstractSynchronousByteArrayCommandTransport.java:35)
 04:23:55        at
 hudson.remoting.SynchronousCommandTransport$ReaderThread.run(SynchronousCommandTransport.java:61)
 04:23:55 Caused: java.io.IOException: Unexpected termination of the
 channel
 on bessie32
 04:00:50  ./topology/test/regress/st_newedgeheal ..FATAL: command
 execution failed
 04:08:56 java.io.EOFException
 04:08:56        at
 04:08:56        at
 04:08:56        at
 04:08:56        at
 04:08:56        at
 04:08:56        at hudson.remoting.Command.readFrom(Command.java:142)
 04:08:56        at hudson.remoting.Command.readFrom(Command.java:128)
 I'm going to test against other branches to see if it is specific to 3.3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5129>
