[postgis-tickets] [PostGIS] #5130: installcheck rule runs topology tests twice (second time without --extension)
PostGIS trac at osgeo.org
Mon Apr 11 15:13:01 PDT 2022
--extension)
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 Ok the problem is in a difference between RUNTESTFLAGS passed as an env
 variable vs. passed as an argument to `make`. Things work when passed as
 env variable, do not when passed as an argument to `make`. Proposed fix:
 https://gitlab.com/postgis/postgis/-/merge_requests/81
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5130#comment:3>
