[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-728-g038a8e4d6
Fri Apr 15 10:29:38 PDT 2022
the project "PostGIS".
       via  038a8e4d6a1dfb293c018409c29b871dc16791fd (commit)
       via  adb8c0ad6e23d23522181746ff6894862b8b893b (commit)
       via  e45a45dafd6379d1b8e6da4d5085db49226e917d (commit)
      from  b39f921427795b27dc121d0de29950b9fac75c97 (commit)
revisions in full, below.
commit 038a8e4d6a1dfb293c018409c29b871dc16791fd
Merge: b39f92142 adb8c0ad6
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Apr 15 13:04:07 2022 -0400
    PG15 Fast GIST index build (Sergei Shoulbakov)
    Closes #5135
    Closes https://github.com/postgis/postgis/pull/684
    Merge remote-tracking branch 'konturio/enable-sorsupport-2d'
diff --cc NEWS
index 68a10949c,840cf1d31..ba531bd9a
--- a/NEWS
+++ b/NEWS
@@@ -24,6 -24,7 +24,7 @@@ PostGIS 3.3.0de
    - ST_ConcaveHull GEOS 3.11+ native implementation (Paul Ramsey, Martin Davis)
    - #4574, GH678, #5121 Enable Link-Time Optimizations using --enable-lto (Sergei Shoulbakov)
    - GH676, faster ST_Clip (Aliaksandr Kalenik)
 -  - Fast GiST index build is enabled by default for PostgreSQL 15+ (Sergei Shoulbakov)
++  - #5135, Fast GiST index build is enabled by default for PostgreSQL 15+ (Sergei Shoulbakov)
   * New features *
    - #5116, Topology export/import scripts (Sandro Santilli)
commit adb8c0ad6e23d23522181746ff6894862b8b893b
Author: sergei sh <sshoulbakov at kontur.io>
Date:   Fri Apr 15 13:25:15 2022 +0300
    News: 2d sortsupport enabled for postgres 15+
diff --git a/NEWS b/NEWS
index e043379ff..840cf1d31 100644
--- a/NEWS
+++ b/NEWS
@@ -24,6 +24,7 @@ PostGIS 3.3.0dev
+  - Fast GiST index build is enabled by default for PostgreSQL 15+ (Sergei Shoulbakov)
  * New features *
commit e45a45dafd6379d1b8e6da4d5085db49226e917d
Date:   Wed Apr 13 16:11:03 2022 +0300
    enable 2d sortsupport function for postgres >= 15
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 115155764..05fb550b3 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -823,9 +823,13 @@ CREATE OPERATOR CLASS gist_geometry_ops_2d
 	OPERATOR        13       <-> FOR ORDER BY pg_catalog.float_ops,
 	OPERATOR        14       <#> FOR ORDER BY pg_catalog.float_ops,
--- Note at 3.2: Sort support in bulk indexing not included in the
--- default opclass due to performance degredation in query
--- may be enabled in future versions.
+-- Sort support in bulk indexing not included in the default
+-- opclass for PostgreSQL versions <15 due to query performance
+-- degradation caused by GiST index page overlap.
+-- Since PostgreSQL 15 sorting build uses picksplit function to
+-- find better partitioning for index records. This allows to
+-- build indices performing similarly to those produced by default
+-- method while still reducing index build time significantly.
 -- To enable sortsupport:
 --   alter operator family gist_geometry_ops_2d using gist
@@ -836,10 +840,9 @@ CREATE OPERATOR CLASS gist_geometry_ops_2d
 --     drop function 11 (geometry);
--- #if POSTGIS_PGSQL_VERSION >= 140
---	FUNCTION        11       geometry_gist_sortsupport_2d (internal),
--- #endif
+#if POSTGIS_PGSQL_VERSION >= 150
+	FUNCTION        11       geometry_gist_sortsupport_2d (internal),
+#endif
 	FUNCTION        8        geometry_gist_distance_2d (internal, geometry, int4),
 	FUNCTION        1        geometry_gist_consistent_2d (internal, geometry, int4),
 	FUNCTION        2        geometry_gist_union_2d (bytea, internal),
Summary of changes:
 NEWS                   |  1 +
 postgis/postgis.sql.in | 17 ++++++++++-------
 2 files changed, 11 insertions(+), 7 deletions(-)
hooks/post-receive
