[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-765-g494ce4273
Sun Apr 17 03:38:51 PDT 2022
the project "PostGIS".
       via  494ce4273c644fd0cd757dd0b64e41b0505f15a9 (commit)
      from  8ddd39e5edd7906c86d46807a15797c490a2b710 (commit)
revisions in full, below.
commit 494ce4273c644fd0cd757dd0b64e41b0505f15a9
Author: Aliaksandr Kalenik <kalenik.aliaksandr at gmail.com>
Date:   Fri Apr 15 20:47:20 2022 +0300
    remove GEOS geometry validation from RT_ST_DumpAsPolygons
diff --git a/NEWS b/NEWS
index ba531bd9a..f9143e372 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 3.3.0dev
   - Drop support for PostgreSQL 9.6 and 10 (Regina Obe)
   - Change output for WKT MULTIPOINT. All points now
     wrapped in parens. (Even Roualt)
+  - GH674, geometry validation and fixing is disabled for ST_DumpAsPolygons
+    so it works faster but might produce invalid polygons.
  * Enhancements *
   - #2861, Add index on topology.node(containing_face) speeding up
diff --git a/raster/rt_core/rt_geometry.c b/raster/rt_core/rt_geometry.c
index b33452ad3..95d5f353c 100644
--- a/raster/rt_core/rt_geometry.c
+++ b/raster/rt_core/rt_geometry.c
@@ -433,9 +433,6 @@ rt_errorstate rt_raster_surface(rt_raster raster, int nband, LWMPOLY **surface)
 		return ES_NONE;
-	/* initialize GEOS */
-	initGEOS(rtinfo, lwgeom_geos_error);
 	/* use gdal polygonize */
 	gv = rt_raster_gdal_polygonize(raster, nband, 1, &gvcount);
 	/* no polygons returned */
@@ -1004,11 +1001,6 @@ rt_raster_gdal_polygonize(
 	int iBandHasNodataValue = FALSE;
 	double dBandNoData = 0.0;
-	/* for checking that a geometry is valid */
-	GEOSGeometry *ggeom = NULL;
-	int isValid;
-	LWGEOM *lwgeomValid = NULL;
 	uint32_t bandNums[1] = {nband};
 	int excludeNodataValues[1] = {exclude_nodata_value};
@@ -1261,40 +1253,6 @@ rt_raster_gdal_polygonize(
 		/* specify SRID */
 		lwgeom_set_srid(lwgeom, rt_raster_get_srid(raster));
-			is geometry valid?
-			if not, try to make valid
-		do {
-			ggeom = (GEOSGeometry *) LWGEOM2GEOS(lwgeom, 0);
-			if (ggeom == NULL) {
-				rtwarn("Cannot test geometry for validity");
-				break;
-			isValid = GEOSisValid(ggeom);
-			GEOSGeom_destroy(ggeom);
-			ggeom = NULL;
-			/* geometry is valid */
-			if (isValid)
-				break;
-			RASTER_DEBUG(3, "fixing invalid geometry");
-			/* make geometry valid */
-			lwgeomValid = lwgeom_make_valid(lwgeom);
-			if (lwgeomValid == NULL) {
-				rtwarn("Cannot fix invalid geometry");
-				break;
-			lwgeom_free(lwgeom);
-			lwgeom = lwgeomValid;
-		while (0);
 		/* save lwgeom */
 		pols[j].geom = lwgeom_as_lwpoly(lwgeom);
Summary of changes:
 NEWS                         |  2 ++
 raster/rt_core/rt_geometry.c | 42 ------------------------------------------
 2 files changed, 2 insertions(+), 42 deletions(-)
hooks/post-receive
