[postgis-tickets] [PostGIS] #5136: debbie failing on raster test
PostGIS trac at osgeo.org
Tue Apr 19 10:48:27 PDT 2022
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.3.0
Component:  raster   |    Version:  master
 Keywords:           |
 Seems since
 [494ce4273c644fd0cd757dd0b64e41b0505f15a9/git]
 22:20:43   Test: test_raster_surface ...FAILED
 22:20:43     1. cu_raster_geometry.c:325  -
 CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(gobserved),lwgeom_area(gexpected),FLT_EPSILON)
 22:20:43     2. cu_raster_geometry.c:339  -
 this is running against
 06:39:53   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.11w64/bin/geos-config
 06:39:53   GEOS version:         3.11.0dev
 06:39:53   GDAL config:
 /var/lib/jenkins/workspace/gdal/rel-3.2w64/bin/gdal-config
 06:39:53   GDAL version:         3.2.3
 06:39:53   SFCGAL config:        /usr/bin/sfcgal-config
 06:39:53   SFCGAL version:       1.3.8
 06:39:53   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg15w64/bin/pg_config
 06:39:53   PostgreSQL version:   PostgreSQL 15devel
 06:39:53   PROJ4 version:        72
 06:39:53   Libxml2 config:       /usr/bin/xml2-config
 06:39:53   Libxml2 version:      2.9.13
 06:39:53   JSON-C support:       yes
 06:39:53   protobuf support:     yes
 06:39:53   protobuf-c version:   1003003
 06:39:53   PCRE support:         not found
 06:39:53   Perl:                 /usr/bin/perl
 I'm going to first try with a newer GDAL to confirm if it's just an issue
 with old GDAL.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5136>
