[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.5-35-gcbb2c9581
Tue Apr 19 22:08:19 PDT 2022
the project "PostGIS".
The branch, stable-2.5 has been updated
       via  cbb2c95815980012c85de5fbe28766b37b048c0c (commit)
      from  b121e7fa1b0f70677ffd83597cfd0873117c41b4 (commit)
revisions in full, below.
commit cbb2c95815980012c85de5fbe28766b37b048c0c
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Apr 20 01:06:24 2022 -0400
    1. Allow detection of pcre using pkg-config
    2. Change windows build to use pkg-config for pcre.  References #4980
       for PostGIS 2.5.6
diff --git a/NEWS b/NEWS
index af99abdc7..cbf7380ed 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 2.5.6
-2022/02/06
+2022/xx/xx
  * Bug fixes *
@@ -18,6 +18,7 @@ PostGIS 2.5.6
            use native GEOS makevalid, buildarea, clipbybox (Regina Obe)
   - #4457, Stop trying to createlang in regress
            plpgsql is always installed (Regina Obe)
+  - Support pkg-config for pcre detection (Regina Obe
 PostGIS 2.5.5
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index f370ab0a3..0081d3be7 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -30,7 +30,7 @@ export PROTOBUFC_VER=1.2.1
 export JSON_VER=0.12
 export PCRE_VER=8.33
 if  [[ "${ICON_VER}" == '' ]] ; then
-  export ICON_VER=1.15
+  export ICON_VER=1.16
 fi;
 echo "ICON_VER ${ICON_VER}"
@@ -144,36 +144,29 @@ fi
 if [ -n "$SFCGAL_VER" ]; then
 	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
-CFLAGS="-Wall -fno-omit-frame-pointer" \
-LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
-  --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
+LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
+./configure \
+  --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
   --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
   --with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
-  --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/gdal-config \
-  --with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
-  --with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
+  --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
   --with-gui --with-gettext=no \
-  --with-protobufdir=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
-  --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE} \
   --without-interrupt-tests \
   --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
+  #exit
 else
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
+LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index d91b43c07..7b186de6d 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -7,8 +7,6 @@ export PROJ_VER=7.2.1
 export SFCGAL_VER=1.4.1
 export ICONV_VER=1.13.1
 if [["${OS_BUILD}" == '64']] ; then
-  export GDAL_VER=2.4.4
-  export SFCGAL_VER=1.4.1
   export ICONV_VER=1.16
 fi;
@@ -51,9 +49,16 @@ fi;
 #set to something even if override is on but not set
 if  [[ "${CGAL_VER}" == '' ]] ; then
-  export CGAL_VER=4.11
+  export CGAL_VER=5.3
 fi;
+echo "ZLIB_VER $ZLIB_VER"
+echo "PROJ_VER $PROJ_VER"
+echo "LIBXML_VER $LIBXML_VER"
+echo "CGAL_VER $CGAL_VER"
 export PROJECTS=/projects
 export MINGPROJECTS=/projects
 export PATHOLD=$PATH
@@ -65,7 +70,9 @@ else
 	export MINGHOST=i686-w64-mingw32
 fi;
-export PATHOLD="/mingw/bin:/mingw/include:/mingw/lib:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin:/c/ming${OS_BUILD}/svn"
+#export PATHOLD="/mingw/bin:/mingw/include:/mingw/lib:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin:/c/ming${OS_BUILD}/svn"
 #export PG_VER=9.2beta2
 export PGWINVER=${PG_VER}edb
 export WORKSPACE=`pwd`
@@ -100,12 +107,16 @@ export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}
 export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-#PATH="${MINGPROJECTS}/gettext/rel-gettext-0.18.1/bin:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}/bin:${PATH}"
-PATH="${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/lib:${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
+export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
 #add protobuf
 export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
 echo PATH AFTER: $PATH
@@ -123,7 +134,6 @@ echo PGIS_REG_TMPDIR IS $PGIS_REG_TMPDIR
 export XSLTPROCFLAGS=
 cd ${POSTGIS_SRC}
 if [ -e ./GNUMakefile ]; then
-  sh autogen.sh
 	make distclean
 fi
@@ -138,39 +148,31 @@ if [ -n "$SFCGAL_VER" ]; then
 	#export CGAL_VER=4.11
 	#BOOST_VER=1.53.0
 	#BOOST_VER_WU=1_49_0
-	#export BOOST_VER_WU=1_53_0
-	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE}/include" \
+./configure \
+  #exit
 else
-  --with-libiconv=${PROJECTS}/rel-libiconv-${ICONV_VER}w${OS_BUILD}${GCC_TYPE} \
diff --git a/configure.ac b/configure.ac
index 3b6df8057..9bab10f77 100644
--- a/configure.ac
+++ b/configure.ac
@@ -472,6 +472,11 @@ if test "x$LIBLWGEOM_ONLY" = "xno"; then
     AC_MSG_ERROR([PostGIS requires PostgreSQL >= 9.4])
   fi
+		dnl Ensure that we are using PostgreSQL < 13
+  if test $POSTGIS_PGSQL_VERSION -gt 120; then
+    AC_MSG_ERROR([This version of PostGIS requires PostgreSQL < 13])
+  fi
   HAVE_BRIN=no
   if test $POSTGIS_PGSQL_VERSION -gt 94; then
     HAVE_BRIN=yes
@@ -1173,6 +1178,17 @@ if test "x$with_address_standardizer" != "xno"; then
                 AC_MSG_ERROR([the --with-pcredir directory "$PCREDIR" cannot be found])
             fi
         fi
+    elif test ! -z "$PKG_CONFIG"; then
+	PKG_CHECK_MODULES([PCRE], [libpcre], [
+                PCRE_CPPFLAGS="$PCRE_CFLAGS"
+                PCRE_LDFLAGS="$PCRE_LIBS"
+                ADDRESS_STANDARDIZER="address_standardizer"
+                HAVE_PCRE=yes
+                ADDRESS_STANDARDIZER=""
+                HAVE_PCRE=no
     fi
@@ -1195,10 +1211,12 @@ if test "x$with_address_standardizer" != "xno"; then
 else
-    AC_SUBST([ADDRESS_STANDARDIZER])
     AC_MSG_RESULT([ADDRESS_STANDARDIZER support: disabled])
 fi
+AC_SUBST([HAVE_PCRE])
+AC_SUBST([ADDRESS_STANDARDIZER])
 CPPFLAGS="$PGSQL_CPPFLAGS $GEOS_CPPFLAGS $PROJ_CPPFLAGS $PROTOBUF_CPPFLAGS $XML2_CPPFLAGS $SFCGAL_CPPFLAGS $JSON_CPPFLAGS $PCRE_CPPFLAGS $CPPFLAGS"
 dnl AC_MSG_RESULT([CPPFLAGS: $CPPFLAGS])
Summary of changes:
 NEWS                         |  3 ++-
 ci/winnie/build_postgis.sh   | 25 ++++++++-------------
 ci/winnie/regress_postgis.sh | 52 +++++++++++++++++++++++---------------------
 configure.ac                 | 20 ++++++++++++++++-
 4 files changed, 57 insertions(+), 43 deletions(-)
hooks/post-receive
