[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.5-37-g33e621799
Wed Apr 20 10:24:13 PDT 2022
the project "PostGIS".
The branch, stable-2.5 has been updated
       via  33e6217994d86b340967e9919b6cb1abdc93bd86 (commit)
      from  8743bc6fe023a5cdb7a6577ac6f85813f550f2b1 (commit)
revisions in full, below.
commit 33e6217994d86b340967e9919b6cb1abdc93bd86
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Apr 20 13:24:07 2022 -0400
    Try to fix windows build
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 0081d3be7..e86795aa2 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -63,11 +63,9 @@ fi;
 if [[ "${GCC_TYPE}" == *gcc48* ]] ; then
 	export PROJECTS=/projects
 	export MINGPROJECTS=/projects
-	export PATHOLD=$PATH
 else
 	#export JSON_VER=0.9
 fi;
@@ -79,7 +77,7 @@ else
 	export MINGHOST=i686-w64-mingw32
 fi;
-export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin:/c/ming${OS_BUILD}/svn"
+#export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin:/c/ming${OS_BUILD}/svn"
 export PGWINVER=${PG_VER}edb
@@ -113,36 +111,49 @@ export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/
 # export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w64
 #export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PATH="${PGPATH}/bin:${PGPATH}/lib:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/xsltproc:${PATH}"
+export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
+export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
 #add protobuf
 export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 echo PATH AFTER: $PATH
-export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig
+echo WORKSPACE IS $WORKSPACE
+#mkdir ${PROJECTS}/postgis/tmp
+export PGIS_REG_TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_MICRO_VER}_pg${PG_VER}_geos${GEOS_VER}_gdal${GDAL_VER}w${OS_BUILD}
+rm -rf ${PGIS_REG_TMPDIR}
+mkdir ${PGIS_REG_TMPDIR}
+export TMPDIR=${PGIS_REG_TMPDIR}
+#rm -rf ${PGIS_REG_TMPDIR}
+#TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_VER}_${PG_VER}_${GEOS_VERSION}_${PROJ_VER}
+echo PORT IS $PGPORT
+echo PGIS_REG_TMPDIR IS $PGIS_REG_TMPDIR
+export XSLTPROCFLAGS=
 cd ${POSTGIS_SRC}
 if [ -e ./GNUMakefile ]; then
 	make distclean
 fi
-echo ${POSTGIS_SRC}
-sh autogen.sh
-#hack to get around boolean incompatibility
-#-D__USE_MINGW_ANSI_STDIO=1
-if [ "$JSON_VER" == "0.9" ] ; then
-	cp ${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/include/json/json_object.h.for_configure ${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/include/json/json_object.h
-fi
-export XSLTPROCFLAGS=
+sh autogen.sh
-#add  PCRE for address standardizer
 if [ -n "$PCRE_VER" ]; then
     export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 fi
 if [ -n "$SFCGAL_VER" ]; then
-	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+	##hard code versions of cgal etc. for now
+	#export CGAL_VER=4.11
+	#BOOST_VER=1.53.0
+	#BOOST_VER_WU=1_49_0
+	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
 ./configure \
@@ -172,6 +183,7 @@ LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYP
   --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
 fi;
 make clean
 #patch liblwgeom generated make to get rid of dynamic linking
 sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
Summary of changes:
 ci/winnie/build_postgis.sh | 44 ++++++++++++++++++++++++++++----------------
 1 file changed, 28 insertions(+), 16 deletions(-)
hooks/post-receive
