[postgis-tickets] [SCM] postgis.net branch website updated. 9ed89ed837fc54ab62d628a622ef094cde155d9e
Wed Apr 20 21:31:56 PDT 2022
the project "postgis.net".
The branch, website has been updated
       via  9ed89ed837fc54ab62d628a622ef094cde155d9e (commit)
      from  1cfefb191d8ac2a5e5bea2b304382fafaa92171f (commit)
revisions in full, below.
commit 9ed89ed837fc54ab62d628a622ef094cde155d9e
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Apr 21 00:31:50 2022 -0400
    PostGIS 2.5.6 release
diff --git a/config/_default/params.toml b/config/_default/params.toml
index e319a8e..f04f908 100644
--- a/config/_default/params.toml
+++ b/config/_default/params.toml
@@ -148,8 +148,8 @@ dev_download = "/stuff"
     tag = "3.0.5"
   [postgis.releases.25]
     minor = "2.5"
-    dev = "2.5.6dev"
-    tag = "2.5.5"
+    dev = "2.5.7dev"
+    tag = "2.5.6"
   [postgis.releases.24]
     minor = "2.4"
     dev = "2.4.10dev"
diff --git a/content/post/2022/04-21_postgis-2.5.6.md b/content/post/2022/04-21_postgis-2.5.6.md
new file mode 100644
index 0000000..3bffbb0
--- /dev/null
+++ b/content/post/2022/04-21_postgis-2.5.6.md
@@ -0,0 +1,59 @@
+title: PostGIS 2.5.6
+layout: post
+category: news
+tags: [release, 2.5]
+author: Regina Obe
+thumbnail:
+date: "2022-04-21"
+The PostGIS Team is pleased to release PostGIS 2.5.6!
+**2.5.6**
+* [source download]({{< loc "postgis.release_source">}}/postgis-2.5.6.tar.gz) [md5]({{postgis.dev_download}}/postgis-2.5.6.tar.gz.md5)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.5.6/NEWS)
+* [PDF docs en]({{< loc "postgis.release_docs">}}/postgis-2.5.6.pdf)
+This release is a bug fix release, addressing issues found in the previous 2.5 releases.
+<!-- pagebreak -->
+**Bug Fixes**
+  - [4968](https://trac.osgeo.org/postgis/ticket/4968) Update autogen.sh to handle autoconf 2.71 issues
+  - [4871](https://trac.osgeo.org/postgis/ticket/4871) TopoGeometry::geometry cast returns NULL for empty
+           TopoGeometry objects (Sandro Santilli)
+  - [4757](https://trac.osgeo.org/postgis/ticket/4757) Handle line collapse due to snap-to-existing node (Sandro Santilli)
+  - [4769](https://trac.osgeo.org/postgis/ticket/4769) Fix segfault in st_addband (Raúl Marín)
+  - [4863](https://trac.osgeo.org/postgis/ticket/4863) Update bboxes after affine/scale operations (Paul Ramsey)
+  - [4326](https://trac.osgeo.org/postgis/ticket/4326) Fix CircularPolygon area calculation (Paul Ramsey)
+  - [4971](https://trac.osgeo.org/postgis/ticket/4971) Cunit fixes for newer CUnit (Raúl Marín, Regina Obe)
+  - [5069](https://trac.osgeo.org/postgis/ticket/5069) search_path vulnerabilty during install/upgrade
+           (Regina Obe)
+  - [5086](https://trac.osgeo.org/postgis/ticket/5086) regress cleanly (clip by box, make valid)
+           with GEOS 3.8+. For GEOS 3.8+
+           use native GEOS makevalid, buildarea, clipbybox (Regina Obe)
+  - [4457](https://trac.osgeo.org/postgis/ticket/4457) Stop trying to createlang in regress
+           plpgsql is always installed (Regina Obe)
+  - [4980](https://trac.osgeo.org/postgis/ticket/4980) Support pkg-config for pcre detection (Regina Obe)
+**Upgrading**
+After installing the binaries or after running pg_upgrade:
+do:
+```postgres
+ALTER EXTENSION postgis UPDATE;
+SELECT postgis_extensions_upgrade();
+If you come across any issues, feel free to report via our [ticket tracker](https://trac.osgeo.org/postgis)
+or [mailing list](https://lists.osgeo.org/listinfo/postgis-users) with details
+View all [tickets for 2.5.6 milestone][1].
+[1]: https://trac.osgeo.org/postgis/query?status=assigned&status=closed&milestone=PostGIS+2.5.6&milestone=PostGIS+2.4.10
Summary of changes:
 config/_default/params.toml              |  4 +--
 content/post/2022/04-21_postgis-2.5.6.md | 59 ++++++++++++++++++++++++++++++++
 2 files changed, 61 insertions(+), 2 deletions(-)
 create mode 100644 content/post/2022/04-21_postgis-2.5.6.md
hooks/post-receive
postgis.net
