[postgis-tickets] [PostGIS] #5141: Unable to upgrade PostGIS from 2.x to 3.2.1 on PostgreSQL 9.6.x
PostGIS trac at osgeo.org
Fri Apr 22 21:47:48 PDT 2022
  Reporter:  milosh                 |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 3.2.2
 Component:  build/upgrade/install  |    Version:  3.2.x
Resolution:                         |   Keywords:  windows
Comment (by robe):
 I think I ran into this issue when upgrading an old database.  I thought
 it was just because I was using a dev version, as I could find the file.
 I think to work around the problem I did these steps:
 CREATE EXTENSION postgis_raster FROM unpackaged;
 DROP EXTENSION postgis_raster; --since you don't need it
 SELECT postgis_extensions_upgrade();
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5141#comment:2>
