[postgis-tickets] [PostGIS] #5141: Unable to upgrade PostGIS from 2.x to 3.2.1 on PostgreSQL 9.6.x
PostGIS trac at osgeo.org
Fri Apr 22 23:22:59 PDT 2022
  Reporter:  milosh                 |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 3.2.2
 Component:  build/upgrade/install  |    Version:  3.2.x
Resolution:                         |   Keywords:  windows
Comment (by milosh):
 When trying
 CREATE EXTENSION postgis_raster from unpackaged
 I get:
 2022-04-23 08:19:32 CEST ERROR:  could not load library "C:/Program
 Files/PostgreSQL/9.6/lib/postgis_raster-3.dll": The specified procedure
 could not be found.
 2022-04-23 08:19:32 CEST STATEMENT:  CREATE EXTENSION postgis_raster from
 unpackaged
 Sysinternals Procmon does not show anything special.
 As a workaround, should I backup the database, then drop it, create new
 one (calling CREATE EXTENSION POSTGIS) and than just do a restore?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5141#comment:4>
