[postgis-tickets] [PostGIS] #5136: debbie failing on raster test
PostGIS trac at osgeo.org
Sun Apr 24 19:50:15 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.0
 Component:  raster   |    Version:  master
Resolution:           |   Keywords:
Comment (by kalenik):
 I tested with 3.2.2 on Ubuntu and it also failed for me.
 cu_raster_geometry.c:325 -- failed with 7 area observed vs 16 expected so
 can't be fixed by tweaking epsilon.
 I can add makevalid back enabled for GDAL < 3.4 but leaning toward
 reverting this change at all.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5136#comment:4>
