[postgis-tickets] [PostGIS] #4984: PostGIS Performance test suite
PostGIS trac at osgeo.org
Fri Apr 29 07:01:27 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  task     |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS Performance
 Component:  postgis  |    Version:  master
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  assigned => closed
 * resolution:   => fixed
Old description:
> I created a separate project at pramsey's suggestion that will be sued
> for doing more intensive tests and tests against real data.
> Project is here - https://git.osgeo.org/gitea/postgis/postgis-performance
> I settled on using pgTap because Vicky likes it and uses it for pgRouting
> so I thought I should know how to use it.
New description:
 I created a separate project at pramsey's suggestion that will be used for
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4984#comment:1>
