[postgis-tickets] [PostGIS] #5142: still failures on marc21 on my local system
PostGIS trac at osgeo.org
Sat Apr 30 13:27:06 PDT 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.3.0
Component:  postgis  |    Version:  master
 Keywords:           |
 The marc21 tests are still failing on my system and only test failing.  It
 works fine on winnie and all other ci bots.  Winnie in theory has the same
 setup as me, so must be something dangling on my computer somewhere.  I
 think I get same issue against pg14 so running pg15 is not the issue.
 I get this regression:
 PostgreSQL 15devel on x86_64-w64-mingw32, compiled by gcc.exe (x86_64
 -posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
   Postgis 3.3.0dev - (3.2.0-782-g89019fa9d) - 2022-04-30 19:54:59
   scripts 3.3.0dev 3.2.0-782-g89019fa9d
   raster scripts 3.3.0dev 3.2.0-782-g89019fa9d
   GEOS: 3.11.0dev-CAPI-1.16.0
   PROJ: 7.2.1
   SFCGAL: 1.4.1
   GDAL: GDAL 3.4.2, released 2022/03/08
  ./regress/core/out_marc21 .. failed (diff expected obtained:
 /projects/postgis/tmp/3.3.0dev_pg15_geos3.11_gdal3.4.2w64/test_27_diff)
 --- ./regress/core/out_marc21_expected  2022-04-30 15:51:40.436946700
 -0400
 +++ /projects/postgis/tmp/3.3.0dev_pg15_geos3.11_gdal3.4.2w64/test_27_out
 2022-04-30 16:01:39.434977000 -0400
 @@ -769,9 +769,9 @@
  polygon_03|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield
 code="d">W058.795833</subfield><subfield
 code="e">W058.414167</subfield><subfield
 code="f">S051.571111</subfield><subfield
 code="g">S051.747222</subfield></datafield></record>
  polygon_04|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">W05847.750000</subfield><subfield
 code="e">W05824.850000</subfield><subfield
 code="f">S05134.266667</subfield><subfield
 code="g">S05144.833333</subfield></datafield></record>
  polygon_05|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">W0584745.000000</subfield><subfield
 code="e">W0582451.000000</subfield><subfield
 code="f">S0513416.000000</subfield><subfield
 code="g">S0514450.000000</subfield></datafield></record>
 -polygon_06|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">W058.795833333333334280723647680133581161499023</subfield><subfield
 code="e">W058.414166666666666571927635231986641883850098</subfield><subfield
 code="f">S051.571111111111115121730108512565493583679199</subfield><subfield
 code="g">S051.747222222222220011644822079688310623168945</subfield></datafield></record>
 -polygon_07|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">W05847.750000000000056843418860808014869689941406250</subfield><subfield
 code="e">W05824.849999999999994315658113919198513031005859375</subfield><subfield
 code="f">S05134.266666666666907303806510753929615020751953125</subfield><subfield
 code="g">S05144.833333333333200698689324781298637390136718750</subfield></datafield></record>
 -polygon_08|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">W0584745.0000000000034106051316484808921813964843750</subfield><subfield
 code="e">W0582450.9999999999996589394868351519107818603515625</subfield><subfield
 code="f">S0513416.0000000000144382283906452357769012451171875</subfield><subfield
 code="g">S0514449.9999999999920419213594868779182434082031250</subfield></datafield></record>
 +polygon_06|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">W058.795833333333334000000000000000000000000000</subfield><subfield
 code="e">W058.414166666666667000000000000000000000000000</subfield><subfield
 code="f">S051.571111111111115000000000000000000000000000</subfield><subfield
 code="g">S051.747222222222220000000000000000000000000000</subfield></datafield></record>
 +polygon_07|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">W05847.750000000000057000000000000000000000000000000</subfield><subfield
 code="e">W05824.849999999999994000000000000000000000000000000</subfield><subfield
 code="f">S05134.266666666666907000000000000000000000000000000</subfield><subfield
 code="g">S05144.833333333333201000000000000000000000000000000</subfield></datafield></record>
 +polygon_08|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">W0584745.0000000000034110000000000000000000000000000</subfield><subfield
 code="e">W0582450.9999999999996590000000000000000000000000000</subfield><subfield
 code="f">S0513416.0000000000144380000000000000000000000000000</subfield><subfield
 code="g">S0514449.9999999999920420000000000000000000000000000</subfield></datafield></record>
  polygon_09|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">-0584745</subfield><subfield
 code="e">-0582451</subfield><subfield
 code="f">-0513416</subfield><subfield
 code="g">-0514450</subfield></datafield></record>
  polygon_10|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">-058.79583</subfield><subfield
 code="e">-058.41417</subfield><subfield
 code="f">-051.57111</subfield><subfield
 code="g">-051.74722</subfield></datafield></record>
  polygon_11|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">-05847.7500</subfield><subfield
 code="e">-05824.8500</subfield><subfield
 code="f">-05134.2667</subfield><subfield
 code="g">-05144.8333</subfield></datafield></record>
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5142>
