[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-782-g8176e19e2
git at osgeo.org
git at osgeo.org
Sat Apr 30 13:41:18 PDT 2022
the project "PostGIS".
via 8176e19e224cfea712acee283b23cfe95bb2cd3d (commit)
from f477f94e54b707fc71cb108c54bf6adb250730ab (commit)
revisions in full, below.
commit 8176e19e224cfea712acee283b23cfe95bb2cd3d
Author: Victor "multun" Collod <victor.collod at epita.fr>
Date: Wed Feb 9 17:33:58 2022 +0100
mvt: introduce feature_builder and fix a buffer overflow
The previous code tried to manually handle resizing the tags array
whenever used, but failed to keep it properly sized.
This commit adds an abstraction over unfinished features, which
enables centralized array size bookkeeping.
Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/92 for PostGIS
3.3.0
Closes #5088 for PostGIS 3.3.0
diff --git a/NEWS b/NEWS
index 629a75bb0..3b84e8795 100644
--- a/NEWS
+++ b/NEWS
@@ -42,6 +42,7 @@ PostGIS 3.3.0dev
- #5100, Support for PostgreSQL 15 (atoi removal) (Laurenz Albe)
- #5123, PG15 now exposes json types and functions, no need
to include for PG15+ (Regina Obe)
+ - #5088, Memory corruption in mvt_agg_transfn (Victor Collod)
PostGIS 3.2.0 (Olivier Courtin Edition)
diff --git a/postgis/mvt.c b/postgis/mvt.c
index 4ae8e6a5f..dc9426303 100644
--- a/postgis/mvt.c
+++ b/postgis/mvt.c
@@ -73,6 +73,70 @@ struct mvt_kv_value {
UT_hash_handle hh;
+/* Must be >= 2, otherwise an overflow will occur at the first grow, as tags come in pairs */
+#define TAGS_INITIAL_CAPACITY 20
+/* This structure keeps track of the capacity of
+ * the tags array while the feature is being built.
+struct feature_builder {
+ bool has_id;
+ uint64_t id;
+ /* A growable array of tags */
+ size_t n_tags;
+ size_t tags_capacity;
+ uint32_t *tags;
+ /* The geometry of the feature. */
+ VectorTile__Tile__GeomType type;
+ size_t n_geometry;
+ uint32_t *geometry;
+static void feature_init(struct feature_builder *builder)
+ builder->has_id = false;
+ builder->n_tags = 0;
+ builder->tags_capacity = TAGS_INITIAL_CAPACITY;
+ builder->tags = palloc(TAGS_INITIAL_CAPACITY * sizeof(*builder->tags));
+ builder->type = VECTOR_TILE__TILE__GEOM_TYPE__UNKNOWN;
+ builder->n_geometry = 0;
+ builder->geometry = NULL;
+static VectorTile__Tile__Feature *feature_build(struct feature_builder *builder)
+ VectorTile__Tile__Feature *feature = palloc(sizeof(*feature));
+ vector_tile__tile__feature__init(feature);
+ feature->has_id = builder->has_id;
+ feature->id = builder->id;
+ feature->n_tags = builder->n_tags;
+ feature->tags = builder->tags;
+ feature->type = builder->type;
+ feature->n_geometry = builder->n_geometry;
+ feature->geometry = builder->geometry;
+ return feature;
+static void feature_add_property(struct feature_builder *builder, uint32_t key_id, uint32_t value_id)
+ size_t new_n_tags = builder->n_tags + 2;
+ if (new_n_tags >= builder->tags_capacity)
+ size_t new_capacity = builder->tags_capacity * 2;
+ builder->tags = repalloc(builder->tags, new_capacity * sizeof(*builder->tags));
+ builder->tags_capacity = new_capacity;
+ builder->tags[builder->n_tags] = key_id;
+ builder->tags[builder->n_tags + 1] = value_id;
+ builder->n_tags = new_n_tags;
static inline uint32_t c_int(enum mvt_cmd_id id, uint32_t count)
return (id & 0x7) | (count << 3);
@@ -138,7 +202,7 @@ static uint32_t encode_ptarray_initial(enum mvt_type type, POINTARRAY *pa, uint3
return encode_ptarray(type, pa, buffer, &px, &py);
-static void encode_point(VectorTile__Tile__Feature *feature, LWPOINT *point)
+static void encode_point(struct feature_builder *feature, LWPOINT *point)
feature->type = VECTOR_TILE__TILE__GEOM_TYPE__POINT;
feature->n_geometry = 3;
@@ -146,7 +210,7 @@ static void encode_point(VectorTile__Tile__Feature *feature, LWPOINT *point)
encode_ptarray_initial(MVT_POINT, point->point, feature->geometry);
-static void encode_mpoint(VectorTile__Tile__Feature *feature, LWMPOINT *mpoint)
+static void encode_mpoint(struct feature_builder *feature, LWMPOINT *mpoint)
size_t c;
// NOTE: inefficient shortcut LWMPOINT->LWLINE
@@ -158,7 +222,7 @@ static void encode_mpoint(VectorTile__Tile__Feature *feature, LWMPOINT *mpoint)
lwline->points, feature->geometry);
-static void encode_line(VectorTile__Tile__Feature *feature, LWLINE *lwline)
+static void encode_line(struct feature_builder *feature, LWLINE *lwline)
size_t c;
feature->type = VECTOR_TILE__TILE__GEOM_TYPE__LINESTRING;
@@ -168,7 +232,7 @@ static void encode_line(VectorTile__Tile__Feature *feature, LWLINE *lwline)
-static void encode_mline(VectorTile__Tile__Feature *feature, LWMLINE *lwmline)
+static void encode_mline(struct feature_builder *feature, LWMLINE *lwmline)
uint32_t i;
int32_t px = 0, py = 0;
@@ -184,7 +248,7 @@ static void encode_mline(VectorTile__Tile__Feature *feature, LWMLINE *lwmline)
feature->n_geometry = offset;
-static void encode_poly(VectorTile__Tile__Feature *feature, LWPOLY *lwpoly)
+static void encode_poly(struct feature_builder *feature, LWPOLY *lwpoly)
uint32_t i;
@@ -200,7 +264,7 @@ static void encode_poly(VectorTile__Tile__Feature *feature, LWPOLY *lwpoly)
-static void encode_mpoly(VectorTile__Tile__Feature *feature, LWMPOLY *lwmpoly)
+static void encode_mpoly(struct feature_builder *feature, LWMPOLY *lwmpoly)
uint32_t i, j;
@@ -219,7 +283,7 @@ static void encode_mpoly(VectorTile__Tile__Feature *feature, LWMPOLY *lwmpoly)
-static void encode_feature_geometry(VectorTile__Tile__Feature *feature, LWGEOM *lwgeom)
+static void encode_feature_geometry(struct feature_builder *feature, LWGEOM *lwgeom)
int type = lwgeom->type;
@@ -402,8 +466,7 @@ static void encode_values(mvt_agg_context *ctx)
kv->value->test_oneof_case = pftype; \
HASH_ADD_KEYPTR_BYHASHVALUE(hh, ctx->hash, &kv->value->pfvaluefield, size, hashv, kv); \
- tags[ctx->row_columns * 2] = k; \
- tags[ctx->row_columns * 2 + 1] = kv->id; \
+ feature_add_property(feature, k, kv->id); \
@@ -442,7 +505,7 @@ static void encode_values(mvt_agg_context *ctx)
static bool
-add_value_as_string_with_size(mvt_agg_context *ctx, char *value, size_t size, uint32_t *tags, uint32_t k)
+add_value_as_string_with_size(mvt_agg_context *ctx, struct feature_builder *feature, char *value, size_t size, uint32_t k)
bool kept = false;
struct mvt_kv_value *kv;
@@ -463,23 +526,23 @@ add_value_as_string_with_size(mvt_agg_context *ctx, char *value, size_t size, ui
HASH_ADD_KEYPTR_BYHASHVALUE(hh, ctx->string_values_hash, kv->value->string_value, size, hashv, kv);
kept = true;
return kept;
/* Adds a string to the stored values. Gets ownership of the string */
static void
-add_value_as_string(mvt_agg_context *ctx, char *value, uint32_t *tags, uint32_t k)
+add_value_as_string(mvt_agg_context *ctx, struct feature_builder *feature, char *value, uint32_t k)
- bool kept = add_value_as_string_with_size(ctx, value, strlen(value), tags, k);
+ bool kept = add_value_as_string_with_size(ctx, feature, value, strlen(value), k);
if (!kept)
pfree(value);
/* Adds a Datum to the stored values as a string. */
static inline void
-parse_datum_as_string(mvt_agg_context *ctx, Oid typoid, Datum datum, uint32_t *tags, uint32_t k)
+parse_datum_as_string(mvt_agg_context *ctx, struct feature_builder *feature, Oid typoid, Datum datum, uint32_t k)
Oid foutoid;
bool typisvarlena;
@@ -488,11 +551,10 @@ parse_datum_as_string(mvt_agg_context *ctx, Oid typoid, Datum datum, uint32_t *t
getTypeOutputInfo(typoid, &foutoid, &typisvarlena);
value = OidOutputFunctionCall(foutoid, datum);
POSTGIS_DEBUGF(4, "parse_value_as_string value: %s", value);
- add_value_as_string(ctx, value, tags, k);
+ add_value_as_string(ctx, feature, value, k);
-static uint32_t *parse_jsonb(mvt_agg_context *ctx, Jsonb *jb,
- uint32_t *tags)
+static void parse_jsonb(mvt_agg_context *ctx, struct feature_builder *feature, Jsonb *jb)
JsonbIterator *it;
JsonbValue v;
@@ -501,7 +563,7 @@ static uint32_t *parse_jsonb(mvt_agg_context *ctx, Jsonb *jb,
uint32_t k;
if (!JB_ROOT_IS_OBJECT(jb))
- return tags;
+ return;
it = JsonbIteratorInit(&jb->root);
@@ -515,14 +577,9 @@ static uint32_t *parse_jsonb(mvt_agg_context *ctx, Jsonb *jb,
k = get_key_index_with_size(ctx, v.val.string.val, v.val.string.len);
if (k == UINT32_MAX)
- char *key;
- uint32_t newSize = ctx->keys_hash_i + 1;
- key = palloc(v.val.string.len + 1);
+ char *key = palloc(v.val.string.len + 1);
memcpy(key, v.val.string.val, v.val.string.len);
key[v.val.string.len] = '\0';
- tags = repalloc(tags, newSize * 2 * sizeof(*tags));
k = add_key(ctx, key);
@@ -533,8 +590,7 @@ static uint32_t *parse_jsonb(mvt_agg_context *ctx, Jsonb *jb,
char *value = palloc(v.val.string.len + 1);
memcpy(value, v.val.string.val, v.val.string.len);
value[v.val.string.len] = '\0';
- ctx->row_columns++;
else if (v.type == jbvBool)
@@ -543,7 +599,6 @@ static uint32_t *parse_jsonb(mvt_agg_context *ctx, Jsonb *jb,
sizeof(protobuf_c_boolean),
bool_value,
VECTOR_TILE__TILE__VALUE__TEST_ONEOF_BOOL_VALUE);
else if (v.type == jbvNumeric)
@@ -567,18 +622,15 @@ static uint32_t *parse_jsonb(mvt_agg_context *ctx, Jsonb *jb,
MVT_PARSE_INT_VALUE(l);
- return tags;
* Sets the feature id. Ignores Nulls and negative values
-static void set_feature_id(mvt_agg_context *ctx, VectorTile__Tile__Feature *feature, Datum datum, bool isNull)
+static void set_feature_id(mvt_agg_context *ctx, struct feature_builder *feature, Datum datum, bool isNull)
Oid typoid = ctx->column_cache.column_oid[ctx->id_index];
int64_t value = INT64_MIN;
@@ -614,10 +666,8 @@ static void set_feature_id(mvt_agg_context *ctx, VectorTile__Tile__Feature *feat
feature->id = (uint64_t) value;
-static void parse_values(mvt_agg_context *ctx, VectorTile__Tile__Feature *feature)
+static void parse_values(mvt_agg_context *ctx, struct feature_builder *feature)
- uint32_t n_keys = ctx->keys_hash_i;
- uint32_t *tags = palloc(n_keys * 2 * sizeof(*tags));
uint32_t i;
mvt_column_cache cc = ctx->column_cache;
uint32_t natts = (uint32_t) cc.tupdesc->natts;
@@ -625,7 +675,6 @@ static void parse_values(mvt_agg_context *ctx, VectorTile__Tile__Feature *featur
HeapTupleData tuple;
POSTGIS_DEBUG(2, "parse_values called");
- ctx->row_columns = 0;
/* Build a temporary HeapTuple control structure */
tuple.t_len = HeapTupleHeaderGetDatumLength(ctx->row);
@@ -668,7 +717,7 @@ static void parse_values(mvt_agg_context *ctx, VectorTile__Tile__Feature *featur
elog(ERROR, "parse_values: unexpectedly could not find parsed key name '%s'", key);
if (typoid == JSONBOID)
- tags = parse_jsonb(ctx, DatumGetJsonbP(datum), tags);
+ parse_jsonb(ctx, feature, DatumGetJsonbP(datum));
continue;
@@ -708,24 +757,16 @@ static void parse_values(mvt_agg_context *ctx, VectorTile__Tile__Feature *featur
VECTOR_TILE__TILE__VALUE__TEST_ONEOF_DOUBLE_VALUE);
break;
case TEXTOID:
- add_value_as_string(ctx, text_to_cstring(DatumGetTextP(datum)), tags, k);
+ add_value_as_string(ctx, feature, text_to_cstring(DatumGetTextP(datum)), k);
break;
case CSTRINGOID:
- add_value_as_string(ctx, DatumGetCString(datum), tags, k);
+ add_value_as_string(ctx, feature, DatumGetCString(datum), k);
break;
default:
- parse_datum_as_string(ctx, typoid, datum, tags, k);
+ parse_datum_as_string(ctx, feature, typoid, datum, k);
break;
- feature->n_tags = ctx->row_columns * 2;
- feature->tags = tags;
- POSTGIS_DEBUGF(3, "parse_values n_tags %zd", feature->n_tags);
/* For a given geometry, look for the highest dimensional basic type, that is,
@@ -993,7 +1034,7 @@ void mvt_agg_transfn(mvt_agg_context *ctx)
Datum datum;
GSERIALIZED *gs;
LWGEOM *lwgeom;
- VectorTile__Tile__Feature *feature;
+ struct feature_builder feature_builder;
VectorTile__Tile__Layer *layer = ctx->layer;
POSTGIS_DEBUG(2, "mvt_agg_transfn called");
@@ -1007,14 +1048,21 @@ void mvt_agg_transfn(mvt_agg_context *ctx)
return;
/* Allocate a new feature object */
- feature = palloc(sizeof(*feature));
- vector_tile__tile__feature__init(feature);
+ feature_init(&feature_builder);
/* Deserialize the geometry */
gs = (GSERIALIZED *) PG_DETOAST_DATUM(datum);
lwgeom = lwgeom_from_gserialized(gs);
- /* Add the feature to the result */
+ /* Set the geometry of the feature */
+ encode_feature_geometry(&feature_builder, lwgeom);
+ lwgeom_free(lwgeom);
+ // TODO: free detoasted datum?
+ /* Parse properties */
+ parse_values(ctx, &feature_builder);
+ /* Grow the features array of the layer */
POSTGIS_DEBUGF(3, "mvt_agg_transfn encoded feature count: %zd", layer->n_features);
if (layer->n_features >= ctx->features_capacity)
@@ -1024,13 +1072,9 @@ void mvt_agg_transfn(mvt_agg_context *ctx)
ctx->features_capacity = new_capacity;
POSTGIS_DEBUGF(3, "mvt_agg_transfn new_capacity: %zd", new_capacity);
- layer->features[layer->n_features++] = feature;
- /* Set the geometry of the feature */
- encode_feature_geometry(feature, lwgeom);
- lwgeom_free(lwgeom);
- // TODO: free detoasted datum?
- parse_values(ctx, feature);
+ /* Build and add the feature to the layer */
+ layer->features[layer->n_features++] = feature_build(&feature_builder);
static VectorTile__Tile * mvt_ctx_to_tile(mvt_agg_context *ctx)
diff --git a/postgis/mvt.h b/postgis/mvt.h
index 11d5dd922..8c7aff485 100644
--- a/postgis/mvt.h
+++ b/postgis/mvt.h
@@ -72,9 +72,12 @@ typedef struct mvt_agg_context
uint32_t geom_index;
HeapTupleHeader row;
+ /* The layer which stores all the aggregated features. Aggregation can only yield a single layer. */
VectorTile__Tile__Layer *layer;
- VectorTile__Tile *tile;
+ /* The size of the features array in the layer */
size_t features_capacity;
+ /* The cached result of the aggregation. It can only be set once the operation is complete. */
+ VectorTile__Tile *tile;
/* Hash table holding the feature keys */
struct mvt_kv_key *keys_hash;
@@ -92,7 +95,6 @@ typedef struct mvt_agg_context
/* Total number of keys stored */
uint32_t keys_hash_i;
- uint32_t row_columns;
mvt_column_cache column_cache;
} mvt_agg_context;
Summary of changes:
NEWS | 1 +
postgis/mvt.c | 160 +++++++++++++++++++++++++++++++++++++---------------------
postgis/mvt.h | 6 ++-
3 files changed, 107 insertions(+), 60 deletions(-)
hooks/post-receive
