[postgis-tickets] [PostGIS] #5136: failures on raster tests - some ci bots running GDAL 3.2 (was: debbie failing on raster test)
PostGIS trac at osgeo.org
Sat Apr 30 17:38:07 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.0
 Component:  raster   |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 I just renabled the berrie bots.
 berrie64 and berrie are both failing with same error and they are both
 running GDAL 3.2.2 on debian with gdal installed from packages.
 I'm going to test with lower GDAL besides 3.1.  At a glance 3.1 seemed
 fine, so this could just be an issue with GDAL 3.2s
 -------------- Dependencies --------------
 16:44:44   GEOS config:
 /home/jenkins/workspace/geos/rel-3.11.0/bin/geos-config
 16:44:44   GEOS version:         3.11.0dev
 16:44:44   GDAL config:          /usr/bin/gdal-config
 16:44:44   GDAL version:         3.2.2
 16:44:44   PostgreSQL config:
 /home/jenkins/workspace/pg/label/berrie64/rel/pg14w64/bin/pg_config
 16:44:44   PostgreSQL version:   PostgreSQL 14.1
 16:44:44   PROJ4 version:        72
 16:44:44   Libxml2 config:       /usr/bin/xml2-config
 16:44:44   Libxml2 version:      2.9.10
 16:44:44   JSON-C support:       yes
 16:44:44   protobuf support:     yes
 16:44:44   protobuf-c version:   1003003
 16:44:44   PCRE support:         Version 1
 16:44:44   Perl:                 /usr/bin/perl
 16:44:44
 16:51:09   Test: test_raster_surface ...FAILED
 16:51:09     1. cu_raster_geometry.c:325  -
 CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(gobserved),lwgeom_area(gexpected),FLT_EPSILON)
 16:51:09     2. cu_raster_geometry.c:339  -
 Note to self, have to change berrie to fail on first failure instead of
 going on to garden tests, as the green is misleading on that one.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5136#comment:6>
