[postgis-tickets] [PostGIS] #5196: CREATE EXTENSION script for postgis_tiger_geocoder should use CREATE FUNCTION
PostGIS trac at osgeo.org
Mon Aug 1 10:49:43 PDT 2022
FUNCTION
 Reporter:  robe            |      Owner:  robe
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 2.5.8
Component:  tiger geocoder  |    Version:  2.5.x
 Keywords:                  |
 Right now it uses CREATE OR REPLACE FUNCTION.  However since CREATE
 EXTENSION there should be none of these functions existing, it should do a
 CREATE FUNCTION instead to prevent overwriting of user functions and also
 hacker exploits.
 This is breaking it out of #5165.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5196>
