[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-31-g296133092
Mon Aug 1 17:38:41 PDT 2022
the project "PostGIS".
       via  2961330921dcd0e09074cc36b2bbef51312959c9 (commit)
       via  ae25d4488b670dc5dfa725c24f4e919ab6122fc0 (commit)
      from  523502dc1f07203b75a5cfeddccdfb3856e78e53 (commit)
revisions in full, below.
commit 2961330921dcd0e09074cc36b2bbef51312959c9
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 1 19:53:17 2022 -0400
    cleanup remove unused functions, fix help
diff --git a/utils/create_or_replace_to_create.pl b/utils/create_or_replace_to_create.pl
index 6b43953f8..650aaa839 100644
--- a/utils/create_or_replace_to_create.pl
+++ b/utils/create_or_replace_to_create.pl
@@ -31,58 +31,12 @@ eval "exec perl -w $0 $@"
 use strict;
 use warnings;
-# Conditionally upgraded types and operators based
-# on their last updated version and the version of
-# the target database
-sub parse_last_updated
-    my $comment = shift;
-    if ( $comment =~ m/.*(?:Availability|Changed|Updated):\s([^\.])\.([^.]*)/s )
-        return $1*100 + $2;
-    return 0;
-sub parse_replaces
-    my @replaces = ();
-    my ($name, $args, $ver);
-    foreach my $line ( split /\n/, $comment )
-        if ( $line =~ m/.*Replaces\s\s*([^\(]*)\(([^\)]*)\)\s\s*deprecated in\s\s*([^\.]*)\.([^.]*)/ )
-            $name = $1;
-            $args = $2;
-            $ver = $3*100 + $4;
-            my @r = ($name, $args, $ver);
-            push @replaces, \@r;
-    return @replaces;
-sub parse_missing
-    my @missing = ();
-    if ( $comment =~ m/.*(?:Missing in):\s([^\.])\.([^.]*)/s )
-        push(@missing, $1*100 + $2);
-    return join(',', at missing);
 # Commandline argument handling
 ($#ARGV == 0)
   ||die
-"Usage: perl create_upgrade.pl <create_script.sql> [<schema>]\nCreates a new SQL script that has all CREATE OR REPLACE converted to CREATE so it is suitable for CREATE EXTENSION only.\n"
+"Usage: perl create_or_replace_to_create.pl <create_script.sql> [<schema>]\nCreates a new SQL script that has all CREATE OR REPLACE converted to CREATE so it is suitable for CREATE EXTENSION only.\n"
   if ( @ARGV < 1 || @ARGV > 3 );
 my $sql_file = $ARGV[0];
@@ -161,8 +115,6 @@ while(<INPUT>)
 close(INPUT);
-#print "COMMIT;\n";
 1;
 __END__
commit ae25d4488b670dc5dfa725c24f4e919ab6122fc0
Date:   Mon Aug 1 19:47:17 2022 -0400
    Try to fix out of tree build, broken by recent extension changes
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 0fa8f7d13..ea980d9af 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -79,13 +79,13 @@ sql/address_standardizer_pre.sql: $(EXTENSION_SCRIPTS)
 sql/address_standardizer--$(EXTVERSION).sql: sql/address_standardizer_pre.sql ../../utils/create_or_replace_to_create.pl
 	mkdir -p sql
 	cat $< \
-		| $(PERL) ../../utils/create_or_replace_to_create.pl sql/address_standardizer_pre.sql \
+		| $(PERL) @top_srcdir@/utils/create_or_replace_to_create.pl sql/address_standardizer_pre.sql \
 sql/address_standardizer.sql: sql/address_standardizer_pre.sql ../../utils/create_or_replace_to_create.pl
 	mkdir -p sql
 	cat $< \
 EXTENSION_UPGRADE_SCRIPTS = sql/address_standardizer_functions.sql
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 49cfd80a1..a0a3fd578 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -81,7 +81,7 @@ sql/$(EXTENSION)_pre.sql: sql/tiger_geocoder.sql  sql_bits/mark_editable_objects
 sql/$(EXTENSION).sql: sql/$(EXTENSION)_pre.sql ../../utils/create_or_replace_to_create.pl
 	cat $< \
-		| $(PERL) ../../utils/create_or_replace_to_create.pl sql/$(EXTENSION)_pre.sql \
+		| $(PERL) @top_srcdir@/utils/create_or_replace_to_create.pl sql/$(EXTENSION)_pre.sql \
 sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
Summary of changes:
 extensions/address_standardizer/Makefile.in   |  4 +--
 extensions/postgis_tiger_geocoder/Makefile.in |  2 +-
 utils/create_or_replace_to_create.pl          | 50 +--------------------------
 3 files changed, 4 insertions(+), 52 deletions(-)
hooks/post-receive
