[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-35-g809148a18
Fri Aug 5 03:36:35 PDT 2022
the project "PostGIS".
       via  809148a1894ac8d80db6e8796b9f78d0622a8651 (commit)
      from  4ef6d4ccac88c06c4e5731c9c9596a26d35a848d (commit)
revisions in full, below.
commit 809148a1894ac8d80db6e8796b9f78d0622a8651
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 5 12:36:15 2022 +0200
    Improve labels on PASS/FAIL/SKIP from unpackaged`
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index d416979fe..427234d8b 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -228,9 +228,9 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
       echo "Testing ${test_label}"
       RUNTESTFLAGS="-v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
       make -C ${REGDIR} check && {
-        echo "PASS: ${EXT} script-based upgrade $UPGRADE_PATH"
+        echo "PASS: ${test_label}"
-        echo "FAIL: ${EXT} script-based upgrade $UPGRADE_PATH"
+        echo "FAIL: ${test_label}"
         failed
     done #}
Summary of changes:
 utils/check_all_upgrades.sh | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
