[postgis-tickets] [PostGIS] #5201: upgrade-path branch fails on windows
PostGIS trac at osgeo.org
Fri Aug 5 10:44:01 PDT 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.3.0
Component:  postgis  |    Version:  master
 Keywords:           |
 strk I tried the upgrade-path branch, fails on make install for me.
 https://git.osgeo.org/gitea/postgis/postgis/src/branch/upgrade-paths
 With this error:
 ---- Making install in postgis
 make[2]: Entering directory '/projects/postgis/tmp/postgis-
 build/3.3/extensions/postgis'
 /bin/mkdir -p 'C:/MING64~1/projects/POSTGR~1/rel/PG15W6~2/share/extension'
 rm -f sql/postgis--TO--ANY.sql
 echo '-- Just tag extension postgis version as "ANY"' > sql/postgis--TO--
 ANY.sql
 echo '-- Installed by postgis 3.3.0dev' >> sql/postgis--TO--ANY.sql
 echo '-- Built on Fri Aug  5 12:05:39 EDT 2022' >> sql/postgis--TO--
 ANY.sql
 tpl='postgis--ANY--3.3.0dev.sql'; \
 /bin/install -c -m 644 sql/${tpl}
 "C:/MING64~1/projects/POSTGR~1/rel/PG15W6~2/share/extension/${tpl}"; \
 /bin/install -c -m 644 "sql/postgis--TO--ANY.sql"
 "C:/MING64~1/projects/POSTGR~1/rel/PG15W6~2/share/extension/postgis--TO--
 ANY.sql"; \
 ln -fs "postgis--TO--ANY.sql"
 3.3.0dev--ANY.sql; \
 /projects/postgis/tmp/postgis-build/3.3/loader/postgis install-upgrade-
 from-available
 /extension: No such file or directory at /projects/postgis/tmp/postgis-
 build/3.3/loader/postgis line 96.
 make[2]: *** [/projects/postgis/postgis-git/extensions/postgis/../upgrade-
 paths-rules.mk:8: install-upgrade-paths] Error 2
 make[2]: Leaving directory '/projects/postgis/tmp/postgis-
 make[1]: *** [Makefile:29: install] Error 1
 make[1]: Leaving directory '/projects/postgis/tmp/postgis-
 build/3.3/extensions'
 make: *** [GNUmakefile:24: install] Error 1
 This is using out of tree build.  I'll try again with in tree.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5201>
