[postgis-tickets] [PostGIS] #5194: SELECT postgis_extensions_upgrade() fails with pgextwlist
PostGIS trac at osgeo.org
Fri Aug 5 17:03:12 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by robe):
 I've worked up a patch I'm testing.  For super users they'll follow the
 same mode, none super users (which is usually only DbaaS users), they'll
 follow the standard upgrade path.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5194#comment:13>
