[postgis-tickets] [PostGIS] #5202: It seems I can downgrade with ANY
PostGIS trac at osgeo.org
Fri Aug 5 19:11:07 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.3.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 I thought we had protection for this, but maybe the protection is only in
 the
 ALTER EXTENSION .. UPDATE;
 machinery.
 To test, I installed postgis 3.3.0dev.
 CREATE EXTENSION postgis;
 Then followed by installing postgis 3.2.2.
 Then run:
 SELECT postgis_extensions_upgrade();
 Downgraded me to 3.2.2.
 You can do the same by messing with the control files
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5202>
