[postgis-tickets] [PostGIS] #5202: It seems I can downgrade with ANY
PostGIS trac at osgeo.org
Fri Aug 5 20:40:48 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"2f08c4f1e916a0ff6412d4ee0980377e74e61d01/git" 2f08c4f/git]:
 {{{#!CommitTicketReference repository="git"
 revision="2f08c4f1e916a0ff6412d4ee0980377e74e61d01"
 1) Only use ANY option if superuser installing
 2) Don't allow downgrade
 3) Schema qual changes
 Closes #5194 for PostGIS 3.3.0
 Closes #5202 for PostGIS 3.3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5202#comment:2>
