[postgis-tickets] [PostGIS] #5202: It seems I can downgrade with ANY
PostGIS trac at osgeo.org
Fri Aug 5 21:53:55 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.2.3
 Component:  build/upgrade/install  |    Version:  3.2.x
Resolution:                         |   Keywords:
Comment (by strk):
 Ok I went looking the code and it does indeed NOT attempt to protect
 against downgrade, but ONLY against "upgrades" between different _major_
 versions. Being 3.3 and 3.2 both in the same "major" version the upgrade
 script does not complain.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5202#comment:4>
