[postgis-tickets] [PostGIS] #5203: 2.5 CI fails with postgis_upgrade.sql:125: invalid command \d.].*',
PostGIS trac at osgeo.org
Sun Aug 7 10:51:44 PDT 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.5.8
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"e5f7f23bf9957be5fdef5a77df84b5468d606fc2/git" e5f7f23/git]:
 {{{#!CommitTicketReference repository="git"
 revision="e5f7f23bf9957be5fdef5a77df84b5468d606fc2"
 Fix syntax of major upgrade function
 This was broken in previous commit
 be4c7b69d697d0819aa68b8ca3af39a95936c1eb
 References #5202
 Closes #5203
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5203#comment:2>
