[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-41-g43ded1ed9
Sun Aug 7 21:21:28 PDT 2022
the project "PostGIS".
       via  43ded1ed950a9255913a0bd358a1a123b5f0323d (commit)
      from  7d50d1b3c7e3e41b6b3a066f51270e29d35de1e7 (commit)
revisions in full, below.
commit 43ded1ed950a9255913a0bd358a1a123b5f0323d
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 8 00:21:22 2022 -0400
    Prep for 3.3.0rc1 release
diff --git a/NEWS b/NEWS
index 80deb6cca..1c8243fad 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.3.0rc1
-2022/xx/xx
+2022/08/xx
 This version requires PostgreSQL 11 or higher, GEOS 3.6 or higher, and Proj 5.2+.
 Additional features are enabled if you are running GEOS 3.9+
 ST_MakeValid enhancements with 3.10+, numerouse additional enhancements with GEOS 3.11+.
@@ -21,7 +21,8 @@ Changes since PostGIS 3.3.0beta2:
   - #5195, #5196  Change address_standardizer
            and postgis_tiger_geocoder CREATE EXTENSION to use CREATE
            instead of CREATE OR REPLACE. (Regina Obe)
+  - #5202, Guard against downgrade (Sandro Santilli)
+  - #5104, postgis_extensions_upgrade() fails with pgextwlist (Regina Obe)
 PostGIS 3.3.0beta2
diff --git a/Version.config b/Version.config
index b7f7afe6e..da74c5bd9 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0rc1
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 7c6873914..94942bee7 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,7 +2,42 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
-        <sect1>
+    <sect1>
+        <title>PostGIS 3.3.0rc1</title>
+        <para>2022/08/08</para>
+        <para>This version requires PostgreSQL 11 or higher, GEOS 3.6 or higher, and Proj 5.2+.
+        Additional features are enabled if you are running GEOS 3.9+
+        ST_MakeValid enhancements with 3.10+, numerous additional enhancements with GEOS 3.11+.
+        Requires SFCGAL 1.4.1+ for ST_AlphaShape and ST_OptimalAlphaShape.</para>
+        <para>NOTE: GEOS 3.11.0 was recently released,
+ details at <ulink url="https://libgeos.org/posts/2022-07-01-geos-3-11-0-released/">GEOS 3.11.0 release notes</ulink></para>
+        <para>The new --enable-lto flag improves speed of math computations.  This new feature is disabled by default
+because on some platforms, causes compilation errors (BSD and MingW64 issues have been raised)</para>
+        <para>Use below to enable it.</para>
+        <programlisting>./configure --enable-lto</programlisting>
+        <para>Changes since PostGIS 3.3.0beta2:</para>
+        <simplesect>
+            <title>Bug Fixes</title>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5154">5154</ulink>, raster ST_Value is undercosted (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5157">5157</ulink>, Revise minimum_bounding_circle Cunit test
+                        to be tolerant of small 32-bit floating point differences
+                        (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5191">5191</ulink>, Functions should use integer instead of int4 (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5139">5139</ulink>, PostGIS causes to_jsonb to no longer be parallel safe,
+                        ST_AsGeoJSON and ST_AsGML are also parallel unsafe
+                        (Regina Obe, Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5025">5025</ulink>, Ensure that additional operators are not appended
+                        when the function and opfamily disagree
+                        about dimensionality (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5195">5195</ulink>, #5196  Change address_standardizer
+                        and postgis_tiger_geocoder CREATE EXTENSION to use CREATE
+                        instead of CREATE OR REPLACE. (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5202">5202</ulink>, Guard against downgrade (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5104">5104</ulink>, postgis_extensions_upgrade() fails with pgextwlist (Regina Obe)</para>
+        </simplesect>
+    </sect1>
+    <sect1>
         <title>PostGIS 3.3.0beta2</title>
         <para>2022/07/13</para>
Summary of changes:
 NEWS                  |  5 +++--
 Version.config        |  2 +-
 doc/release_notes.xml | 37 ++++++++++++++++++++++++++++++++++++-
 3 files changed, 40 insertions(+), 4 deletions(-)
hooks/post-receive
