[postgis-tickets] [SCM] postgis.net branch website updated. 52aae6201b1c07a7b11bc3a8b41d2d0b0f4e4304
Sun Aug 7 23:39:48 PDT 2022
the project "postgis.net".
The branch, website has been updated
       via  52aae6201b1c07a7b11bc3a8b41d2d0b0f4e4304 (commit)
      from  fa869efb831d0c3e975dacf34c6f8ca3abbe29d1 (commit)
revisions in full, below.
commit 52aae6201b1c07a7b11bc3a8b41d2d0b0f4e4304
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 8 02:39:42 2022 -0400
    Release 3.3.0rc1
diff --git a/config/_default/params.toml b/config/_default/params.toml
index 2f6aab2..4175726 100644
--- a/config/_default/params.toml
+++ b/config/_default/params.toml
@@ -137,7 +137,7 @@ dev_download = "/stuff"
   [postgis.releases.dev]
     minor = "3.3"
     dev = "3.3.0dev"
-    tag = "3.3.0beta2"
+    tag = "3.3.0rc1"
     is_dev = true
   [postgis.releases.32]
     minor = "3.2"
diff --git a/content/post/2022/08-08_postgis-3.3.0rc1.md b/content/post/2022/08-08_postgis-3.3.0rc1.md
new file mode 100644
index 0000000..909341e
--- /dev/null
+++ b/content/post/2022/08-08_postgis-3.3.0rc1.md
@@ -0,0 +1,75 @@
+title: PostGIS 3.3.0rc1
+layout: post
+category: news
+tags: [release, 3.3]
+author: Regina Obe
+thumbnail:
+date: "2022-08-08"
+The PostGIS Team is pleased to release PostGIS 3.3.0rc1!
+Best Served with [PostgreSQL 15 beta2](https://www.postgresql.org/about/news/postgresql-15-beta-2-released-2479/)
+,[GEOS 3.11.0](https://libgeos.org/posts/2022-07-01-geos-3-11-0-released/)
+, and [SFCGAL 1.4.1](https://gitlab.com/Oslandia/SFCGAL/-/tags/v1.4.1)
+Lower versions of the aforementioned dependencies will not have all new features.
+This release supports PostgreSQL 11-15.
+**3.3.0rc1**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.3.0rc1.tar.gz) [md5]({{< loc "postgis.dev_download">}}/postgis-3.3.0rc1.tar.gz.md5)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.3.0rc1/NEWS)
+* [PDF docs en]({{< loc "postgis.release_docs">}}/postgis-3.3.0rc1.pdf)
+This release is a release candidate of a major release, it includes bug fixes since PostGIS 3.2.2 and new features.
+<!--more-->
+Changes since PostGIS 3.3.0beta2:
+**Bug fixes**
+  - [#5154](https://trac.osgeo.org/postgis/ticket/5154) raster `ST_Value` is undercosted (Regina Obe)
+  - [#5157](https://trac.osgeo.org/postgis/ticket/5157) Revise minimum_bounding_circle Cunit test
+           to be tolerant of small 32-bit floating point differences
+           (Regina Obe)
+  - [#5191](https://trac.osgeo.org/postgis/ticket/5191) Functions should use integer instead of int4 (Regina Obe)
+  - [#5139](https://trac.osgeo.org/postgis/ticket/5139) PostGIS causes to_jsonb to no longer be parallel safe,
+           `ST_AsGeoJSON` and `ST_AsGML` are also parallel unsafe
+           (Regina Obe, Paul Ramsey)
+  - [#5025](https://trac.osgeo.org/postgis/ticket/5025) Ensure that additional operators are not appended
+           when the function and opfamily disagree
+           about dimensionality (Paul Ramsey)
+  - [#5195](https://trac.osgeo.org/postgis/ticket/5195), [#5196](https://trac.osgeo.org/postgis/ticket/5196) Change address_standardizer
+           and postgis_tiger_geocoder CREATE EXTENSION to use CREATE
+           instead of CREATE OR REPLACE. (Regina Obe)
+  - [#5202](https://trac.osgeo.org/postgis/ticket/5202) Guard against downgrade (Sandro Santilli)
+  - [#5104](https://trac.osgeo.org/postgis/ticket/5104) postgis_extensions_upgrade() fails with pgextwlist (Regina Obe)
+**Upgrading**
+After installing the binaries or after running pg_upgrade:
+For PostGIS 3.2, 3.1, 3.0
+do below which will upgrade all your postgis extensions.
+```postgres
+SELECT postgis_extensions_upgrade();
+For PostGIS 2.5 and below do:
+```postgres
+ALTER EXTENSION postgis UPDATE;
+If you come across any issues, feel free to report via our [ticket tracker](https://trac.osgeo.org/postgis)
+or [mailing list](https://lists.osgeo.org/listinfo/postgis-users) with details
+View all [tickets for 3.3.0rc1 milestone][1].
+[1]: https://trac.osgeo.org/postgis/query?status=closed&milestone=PostGIS+3.3.0&milestone=PostGIS+3.2.2&milestone=PostGIS+3.2.1&milestone=PostGIS+3.1.6
Summary of changes:
 config/_default/params.toml                 |  2 +-
 content/post/2022/08-08_postgis-3.3.0rc1.md | 75 +++++++++++++++++++++++++++++
 2 files changed, 76 insertions(+), 1 deletion(-)
 create mode 100644 content/post/2022/08-08_postgis-3.3.0rc1.md
hooks/post-receive
postgis.net
